i want to crate a line according to point with the reference of object id.
Ex- Input Point data
Output that i want
So please tell me how to do this.
Thanks in advance...
Regards Kapil
You can use the tool:: Points To Line—Help | ArcGIS for Desktop
Thanks for help.
I have one more query. I want to create network line according to previous value.
Thanks in advance
No it doesn't. The unique field (Line field) specifies a separation between lines.
The sort field specifies the order in which the points should be.
If you have only 1 line, leave out the unique id.
If the order of your points as they appear in the table is different from the actual connection order, use the sort field.
Tnx frnds.
But point to line tool are work in unique value. But you see in upper snap, i have sequential number. that time he does not work. i want he considered previous and next value to create a line.
