How can you display layered infowindows in javascript for a map with layered feature layers, the way arcgis online maps does it? For example, if you have a layer with point locations, and a layer with aggregate data, say by county, when you click on a point, you get a next window arrow in the upper right corner of the infowindow, and a (1 of 2) or (1 of 3) indicator in the upper left, when working with a map on argis online. I want to produce the same functionality in javascript. In other words, I want to get to the layer info in lower layers without having to turn off the upper layer. Will just layering a semi-transparent point layer on top of a shape layer do the trick?
Thanks in advance,
Don
EMU
