Here's an example of the only thing I could get to work.... and even then, it rearranges the draw order of the graphics... which I couldn't figure out a way to prohibit.
I'm using a slider to hide or peal through graphics.
var searchslider = new RangeSlider({ name: "slider", value: [ 0, 500000 ], minimum: 0, maximum: 500000, intermediateChanges: true, //discreteValues:100, //The number of possible discrete slider values (make increments of 10) no worky skip:1000, showButtons: false, // false by default? style: "width:300px;",
onChange: function(values){ console.log( values[0]+", "+values[1] ); var min = addCommas( values[0].toFixed(0) ); // cutt off all decimals var max = addCommas( values[1].toFixed(0) ); $("#rngMin").html("1:"+min); $("#rngMax").html("1:"+max); //console.log(graphicsLayer.graphics); console.log(graphicsLayer.graphics.length); if (graphicsLayer.graphics.length > 0){ var tempFeatures = graphicsLayer.graphics.items; dojo.forEach(tempFeatures, function(g){ console.log(g); if (g.visible = true && g.attributes.scale_1 > values[1]){ //console.log("true!"); graphicsLayer.remove(g); var hiddenGraphic = new Graphic({ geometry: g.geometry, attributes: g.attributes, popupTemplate: template, symbol: hiddensymbol, visible: false }); graphicsLayer.add(hiddenGraphic); } else if (g.visible == false && g.attributes.scale_1 < values[1]){ graphicsLayer.remove(g); var visibleGraphic = new Graphic({ geometry: g.geometry, attributes: g.attributes, popupTemplate: template, symbol: fillSymbol, visible: true }); graphicsLayer.add(visibleGraphic); } }); //end .each } // end if } // end onchange() }, "mapbib-slider");
setting the symbol to null does not seem to dynamically hide the symbol. You'd still have to remove and add the graphic to the map for it to take effect?
