I need to merge all polygon features in a given feature class into a single polygon. The intended functionality is similar to the "Merge" tool under the Edit->Tools tab. The Merge_management tool takes feature classes as an input and I cannot find documentation on the difference/command for this "Edit->Merge."
I figure I will have to iterate through my feature class using a search cursor and use the dissolve tool to merge the features. I have tried iterations of the following to no avail:
with ap.da.SearchCursor(feature_class, "*") as cursor:
feature_list = []
for row in cursor:
feature_list.append(row)
ap.Dissolve_management(feature_list, out_feature_class, {dissolve_field},{statistics_fields}, {multi_part}, {unsplit_lines})<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>My question is what do I use as my in_features (first field in ap.Dissolve_management)? How do I pass the features into the ap.Dissolve_management function?
