using System; using System.Collections.Generic; using System.Linq; using System.Text; using ESRI.ArcGIS.Geometry; using ESRI.ArcGIS.Geodatabase; using ESRI.ArcGIS.DataSourcesGDB; using System.Collections; namespace TestParallelogram { class Program { static void Main(string[] args) { //Get license. ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.EngineOrDesktop); //Get workspace. IWorkspaceFactory wsfact = new FileGDBWorkspaceFactoryClass(); IFeatureWorkspace featws = (IFeatureWorkspace)wsfact.OpenFromFile("C:\\temp\\Shapes.gdb", 0); //Get polygon layer and loop features testing for parallelogram. IFeatureClass fc = featws.OpenFeatureClass("Shapes"); IFeatureCursor fcursor = fc.Search(null, false); IFeature feat = fcursor.NextFeature(); Console.WriteLine("Press any key to continue..."); Console.WriteLine(); Console.WriteLine("Is feature a parallelogram true/false?"); while (feat != null) { Console.WriteLine("Feature OID = " + feat.OID + " " + IsParallelogram((IPolygon)feat.Shape)); feat = fcursor.NextFeature(); } Console.ReadKey(); } private static bool IsParallelogram(IPolygon pPoly) { bool passesTest = true; pPoly.SimplifyPreserveFromTo(); //Check for arcs/bezier type curves in the polygon. ISegmentCollection segmentCollection = (ISegmentCollection)pPoly; for (int x = 0; x <= segmentCollection.SegmentCount - 1; x++) { if (segmentCollection.get_Segment(x).GeometryType != esriGeometryType.esriGeometryLine) { passesTest = false; } } //If no curves found keep going if (passesTest == true) { Double pi = Math.Round(3.14159250439667, 4); //al holds straight segments of poly i.e. vertex to vertex ArrayList al = new ArrayList(); //alFinal holds final 4 segments of poly after removing vertices that //don't create an angle i.e. a straight line with a vertex in the middle. ArrayList alFinal = new ArrayList(); //create lines from vertex to vertex around polygon. IPointCollection ptcol = (IPointCollection)pPoly; ILine pLine; for (int x = 1; x != ptcol.PointCount; x++) { pLine = new LineClass(); pLine.PutCoords(ptcol.get_Point(x - 1), ptcol.get_Point(x)); al.Add(pLine); } //Try to account for 4 straight lines around polygon. ILine line1; ILine line2; if (al.Count >= 4)//If less than 4 then it is a circle, ellipse or possibly a triangle. { GeometryEnvironment geometryEnvironment = new GeometryEnvironment(); IConstructAngle constructAngle = geometryEnvironment as IConstructAngle; ILine straightLine; line1 = (ILine)al[0]; line2 = (ILine)al[1]; int n = 1; while (n < al.Count) { //Console.WriteLine(constructAngle.ConstructThreePoint(line1.FromPoint, line2.FromPoint, line2.ToPoint)); //Check if angle changes between 2 segments going around the poly. if (Math.Abs(Math.Round(constructAngle.ConstructThreePoint(line1.FromPoint, line2.FromPoint, line2.ToPoint), 4)) == Math.Abs(pi)) { //No change in angle so vertex splits poly edge, but //line doesn't change direction - go to next segment. n++; line2 = (ILine)al; } else { //Line changes direction so add segment to final line group. straightLine = new LineClass(); straightLine.PutCoords(line1.FromPoint, line2.FromPoint); alFinal.Add(straightLine); //Increment n for next set of lines line1 = line2; n++; if (n == al.Count)//Reached last line segment in poly so just add to final group. { straightLine = new LineClass(); straightLine.PutCoords(line2.ToPoint, line2.FromPoint); alFinal.Add(straightLine); } else { line2 = (ILine)al; //Go to next segment in poly } } } } else //less than 4 segments not enough segments to make a parallelogram. { passesTest = false; } //Check that you have 4 straight lines. if (alFinal.Count == 4) { //Check that opposite sides are equal length. //I'm rounding because if you digitize a rectangle their opposite lengths don't actually match! line1 = (ILine)alFinal[0]; line2 = (ILine)alFinal[2]; if (Math.Round(line1.Length, 1) != Math.Round(line2.Length, 1)) passesTest = false; line1 = (ILine)alFinal[1]; line2 = (ILine)alFinal[3]; if (Math.Round(line1.Length, 1) != Math.Round(line2.Length, 1)) passesTest = false; } else //Too many polygon edges. { passesTest = false; } } return passesTest; } } }
