formatResults = arrayUtils.map(results, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = result.layerName; return feature; });
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://js.arcgis.com/3.8/"></script> <script> var map; var identifyTask, identifyParams, idPoint; var identifyResults; require([ "esri/map", "esri/dijit/Popup", "dojo/promise/all", "dojo/domReady!" ], function ( Map, Popup, All ) { var popup = new Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); map = new Map("map", { basemap: "satellite", center: [-83.275, 42.573], zoom: 18, infoWindow: popup }); dojo.connect(map, "onLoad", mapReady); var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer", { opacity: .55 }); map.addLayer(landBaseLayer); var militaryLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/MapServer", { opacity: .55 }); map.addLayer(militaryLayer); function mapReady(map) { dojo.connect(map, "onClick", runIdentifies); } function runIdentifies(evt) { identifyResults = []; idPoint = evt.mapPoint; var layers = dojo.map(map.layerIds, function (layerId) { return map.getLayer(layerId); }); layers = dojo.filter(layers, function (layer) { if (layer.visibleLayers[0] !== -1) { return layer.getImageUrl && layer.visible } }); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers var tasks = dojo.map(layers, function (layer) { return new esri.tasks.IdentifyTask(layer.url); }); //map each visible dynamic layer to a new identify task, using the layer url var defTasks = dojo.map(tasks, function (task) { return new dojo.Deferred(); }); //map each identify task to a new dojo.Deferred var params = createIdentifyParams(layers, evt); var promises = []; for (i = 0; i < tasks.length; i++) { promises.push(tasks.execute(params)); //Execute each task } var allPromises = new All(promises); allPromises.then(function (r) { showIdentifyResults(r, tasks); }); } function showIdentifyResults(r, tasks) { var results = []; var taskUrls = []; r = dojo.filter(r, function (result) { return r[0]; }); for (i = 0; i < r.length; i++) { results = results.concat(r); for (j = 0; j < r.length; j++) { taskUrls = taskUrls.concat(tasks.url); } } results = dojo.map(results, function (result, index) { var feature = result.feature; var layerName = result.layerName; var serviceUrl = taskUrls[index]; feature.attributes.layerName = result.layerName; var template = new esri.InfoTemplate("", "Service Url: " + serviceUrl + "<br/><br/>Layer name: " + result.layerName + "<br/><br/> Object Id: ${OBJECTID}"); feature.setInfoTemplate(template); var resultGeometry = feature.geometry; var resultType = resultGeometry.type; return feature; }); if (results.length === 0) { map.infoWindow.clearFeatures(); } else { map.infoWindow.setFeatures(results); } map.infoWindow.show(idPoint); return results; } function createIdentifyParams(layers, evt) { var identifyParamsList = []; identifyParamsList.length = 0; dojo.forEach(layers, function (layer) { var idParams = new esri.tasks.IdentifyParameters(); idParams.width = map.width; idParams.height = map.height; idParams.geometry = evt.mapPoint; idParams.mapExtent = map.extent; idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; var visLayers = layer.visibleLayers; if (visLayers !== -1) { var subLayers = []; for (var i = 0; i < layer.layerInfos.length; i++) { if (layer.layerInfos.subLayerIds == null) subLayers.push(layer.layerInfos.id); } idParams.layerIds = subLayers; } else { idParams.layerIds = []; } idParams.tolerance = 3; idParams.returnGeometry = true; identifyParamsList.push(idParams); }); return identifyParamsList; } }); </script> </head> <body></body> </html>
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://js.arcgis.com/3.8/"></script> <script> dojo.require("esri.map"); dojo.require("esri.dijit.Popup"); dojo.require("dojo.DeferredList"); dojo.require("dojo.promise.all"); var map; var identifyTask, identifyParams, idPoint; var identifyResults; function init() { var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); map = new esri.Map("map", { basemap: "satellite", center: [-83.275, 42.573], zoom: 18, infoWindow: popup }); dojo.connect(map, "onLoad", mapReady); var landBaseLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer", { opacity: .55 }); map.addLayer(landBaseLayer); var militaryLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Military/MapServer", { opacity: .55 }); map.addLayer(militaryLayer); } function mapReady(map) { dojo.connect(map, "onClick", runIdentifies); } function runIdentifies(evt) { identifyResults = []; idPoint = evt.mapPoint; var layers = dojo.map(map.layerIds, function (layerId) { return map.getLayer(layerId); }); layers = dojo.filter(layers, function (layer) { if (layer.visibleLayers[0] !== -1) { return layer.getImageUrl && layer.visible } }); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers var tasks = dojo.map(layers, function (layer) { return new esri.tasks.IdentifyTask(layer.url); }); //map each visible dynamic layer to a new identify task, using the layer url var defTasks = dojo.map(tasks, function (task) { return new dojo.Deferred(); }); //map each identify task to a new dojo.Deferred var params = createIdentifyParams(layers, evt); var promises = []; for (i = 0; i < tasks.length; i++) { promises.push(tasks.execute(params)); //Execute each task } var allPromises = new dojo.promise.all(promises); allPromises.then(function (r) { showIdentifyResults(r, tasks); }); } function showIdentifyResults(r, tasks) { var results = []; var taskUrls = []; r = dojo.filter(r, function (result) { return r[0]; }); for (i = 0; i < r.length; i++) { results = results.concat(r); for (j = 0; j < r.length; j++) { taskUrls = taskUrls.concat(tasks.url); } } results = dojo.map(results, function (result, index) { var feature = result.feature; var layerName = result.layerName; var serviceUrl = taskUrls[index]; feature.attributes.layerName = result.layerName; var template = new esri.InfoTemplate("", "Service Url: " + serviceUrl + "<br/><br/>Layer name: " + result.layerName + "<br/><br/> Object Id: ${OBJECTID}"); feature.setInfoTemplate(template); var resultGeometry = feature.geometry; var resultType = resultGeometry.type; return feature; }); if (results.length === 0) { map.infoWindow.clearFeatures(); } else { map.infoWindow.setFeatures(results); } map.infoWindow.show(idPoint); return results; } function createIdentifyParams(layers, evt) { var identifyParamsList = []; identifyParamsList.length = 0; dojo.forEach(layers, function (layer) { var idParams = new esri.tasks.IdentifyParameters(); idParams.width = map.width; idParams.height = map.height; idParams.geometry = evt.mapPoint; idParams.mapExtent = map.extent; idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE; var visLayers = layer.visibleLayers; if (visLayers !== -1) { idParams.layerIds = layer.visibleLayers; } else { idParams.layerIds = []; } idParams.tolerance = 3; idParams.returnGeometry = true; identifyParamsList.push(idParams); }); return identifyParamsList; } dojo.ready(init); </script> </head> <body> <div id="map"></div> </body> </html>
