# to make a keyfile # 26 April 2010 kimo # much better than MakeQueryTable and it works across geodatabases # still uses an SQL query but python generates the set for the expression # will work for tens of thousands of keys (amazing) # if you want to save the featureclass or table as a layer or view definition # to use in ArcMap (without making a copy) you MUST have an index on the key field # or it will be extremely slow to draw. # see the Keyfile tool in ArcScripts for an alternative method using selection sets in ArcMap import arcgisscripting,sys,os,datetime,fileinput gp = arcgisscripting.create(9.3) def titlekey(title) : gp.Workspace = ws # Make a title set to use as a keyfile lstTitle = [] cur = gp.SearchCursor(title) row = cur.next() while row : lstTitle.append(row.ttl_title_no) row = cur.next() del row,cur return set(lstTitle) def title_tab(src) : " use setTitle to export records to a table" start = datetime.datetime.now() gp.Workspace = ws setTitle = titlekey(title) expTitle = ",".join(["'"+t+"'" for t in setTitle]) sqlQuery = "ttl_title_no in ("+expTitle+")" gp.MakeTableView_management(src,src+"_view",sqlQuery,wsout) gp.OverwriteOutput = True gp.CopyRows_management(src+"_view",wsout+"/"+src+"_sub") print gp.GetCount(wsout+"/"+src+"_sub").Getoutput(0),"records in "+src+"_sub" print datetime.datetime.now() - start # ------------------------- main ------------------------- title = "e:/arrears.mdb/title" ws = "e:/memo.gdb" wsout = "e:/arrears.mdb" # create subsets based on title keys if not gp.Exists(wsout+"/tta_sub") : title_tab("tta")
myList = ["apple","pear","orange"] for item in myList: # Select item in list based on field COUNTRY. qry = "\"COUNTRY\" = '"+item+"'" gp.Select_analysis(inFile, outDir, qry)
