Any chance to get this working in 9.3?
You should not have to change anything. Just check on the FuelConsumption attribute in the Accumulation tab on the analysis layer's property pages. If it is not accumulating the values properly for some reason, please post an example of what appears to be incorrect.
This is certainly a reasonable approximation. However, please note that if you simply select those parts of the network for which "to_fuelconsumption <= maximum fuel in car", then you could run into the exact same problem I was mentioning earlier about finding infeasible routes due to having a subpath which itself exceeds fuel capacity (even if the full shortest path does not). What you really want is to find only those parts of the network which are reachable within your fuel capacity and for which no subpath from the source exceeds fuel capacity. Does this make sense?
Do I have to change anything in the network properties (besides the stuff which you already told me before in the thread) for the accumulation of the fuel with negative values?
I was thinking about the option to take the distance as the impedance attribute and choose a value much higher than the car actually could drive without refueling. I then wanted to make a selection from the accumulated fuel-attribute with "to_fuelconsumption <= maximum fuel in car"
its actually for electric vehicles. when they are driving downhill section and when they are recuperating (reusing breakenergy) then they actually receive some energy when driving downhill, thus the negative values πUsing the fuel consumption as accumulated attribute works fine, when i would look for a service area with a certain distance, like 100 km, but thats unfortunately not the case π so is there really no possible way to get this thing worked out with the fuelconsumption as impedance attribute?
