Yup, that is why I suggested in making AutoSave to false and just explicitly call SaveEdits() http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.FeatureLayer~SaveEdits.html when the geometry change seem correct 😛This should give you a chance to undo or cancel the changes in the Editor's EditCompleted event.
If you want to accept the change in geometry caused by Cut/Reshape/Union/EditVertices, you can explicitly call SaveEdits(). Otherwise to revert back to the old geometry, the only way is to call FeatureLayer.Update().Another option is to use v2.1 RTM. Like I said in my previous post, CancelActive command will also cancel edits made by EditVertices command if it were the active command and the changes were not yet commited. However, Cut/Reshape/Union does not cancel their edit with CancelActive command even with v2.1 RTM. The reason is because, the GeometryService call performs this change instantaneously; unlike EditVertices where you have to click back on the feature to finalize the edit. For this case, I would advise to do the first approach.
