Al, Use ArcGIS Server 10 or greater or specify symbology for that layer (which I don't believe is supported in the App Builder GUI, but can easily be done my editing the config.xml manually).Documentation for this found here: look for the Rendering and Symbology section. http://resources.arcgis.com/en/help/flex-viewer/concepts/01m3/01m300000053000000.htmDon't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow these steps as shown in the below graphic:
Al,Another option to preserve the colors in arcmap would be to make a map document with just the lines, another for the points (basically, a mxd and thus a service for each layer). Then you can add the "folder", but will only have the one sevice in it, will be "similar" to adding just the layer but will honor the symbology set in ArcMap. R_Flex app in the browser is the "client".
Hi,Question:Using ArcGIS viewer for flex 3.1, changes poly line color to black when you add operational layers, but when you include the operational layer as a folder. all the lines and points display the correct colors set up in Arcmap. I would like to include operational layers seperatly not as folder. What can I do to have application builder display the poly line color the same as in Arcmap?Thank you in advance for your help.Al
Al, What version of ArcGIS Server are you using? The difference in adding the folder as you call it, adds the Map Service as a dynamic layer and thus the rendering is done on the server and images are returned to the client and adding individual layers the rendering is done client side.
