// this snippet is set in the app init // where: // wfsURL==String var // campusMapParams.geoserver == your WFS server // qLayers==Array holding layer names you want to query // srs==spatial reference that applies to the WFS server you want to query, for geoserver its EPSG references wfsURL=campusMapParams.geoserver+"wfs?request=GetFeature&version=1.1.0&typeName="+qLayers.toString()+"&srs="+srs; protected function doIdentifyAll(event:MapMouseEvent): void { var getWFS:HTTPService=new HTTPService; // we'll use a DWITHIN filter to grab any features that are within 25 meters or so // NOTE DWITHIN units MUST match the point coords, ie degrees!! var idPoint:String=String(event.latLng.lng())+","+String(event.latLng.lat()); // google's coords are all geographic so we'll stick w/EPSG:4326 getWFS.url=wfsURL+'&FILTER=<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">' + '<DWithin><PropertyName>the_geom</PropertyName>' + '<gml:Point srsName="EPSG:4326"><gml:coordinates>' +idPoint +'</gml:coordinates></gml:Point><Distance units="deg">0.000050</Distance></DWithin></Filter>'; getWFS.method="GET"; getWFS.resultFormat="e4x"; getWFS.addEventListener("result", identifyAllFeaturesHandler); getWFS.addEventListener("fault", httpServiceFault); getWFS.useProxy=false; try { getWFS.send(); } catch (error:Error) { informUser("Fatal error: Unable to perform identify features on geoserver " + error,"WFS identify all","error"); } } protected function identifyAllFeaturesHandler(event:ResultEvent):void { var results:XML=event.result as XML; var features:XMLList=results.gml::featureMembers.children(); var gid:String=""; var featureAttributes:ArrayCollection=new ArrayCollection(); for (var i:int = 0; i < features.length(); i++) { gid=features.@gml::id; var thisFeature:Object=parseAttributes(features); for (var x:String in thisFeature) { featureAttributes.addItem({layer:gid,attribute:x,value:thisFeature}); } } if (featureAttributes.length==0) informUser("No features found at that point","Identify"); else { if (idResultWindow) // get rid of last one no matter what PopUpManager.removePopUp(idResultWindow); // clean slate idResultWindow=IdentifyResultWindow(PopUpManager.createPopUp(this,IdentifyResultWindow,false)); idResultWindow.dataSource=featureAttributes; } } protected function parseAttributes(xmlNode:XML):Object { var nodes:XMLList = xmlNode.children(); var attributes:Object = {}; for(var i:int = 0; i < nodes.length(); i++) { var name:String = nodes.localName(); var value:Object = nodes.valueOf(); if(name == null || name=="the_geom") continue; // Check for a leaf node if((nodes.children().length() == 1) && !(nodes.children().children()[0] is XML)) attributes[name] = value.children()[0].toXMLString(); extend(attributes, this.parseAttributes(nodes)); } return attributes; }
