Hi!
I would like to indicate the direction of flow for a polyline and also for a polygon. I'd like each segment of the multipart to have an arrowhead (or just a triangle graphic) at the tip. What tools does ArcGIS for Qt/C++ have for something like this? How would I go about making arrows?
Thank you!
Nick
Hi Nicholas,
assuming you can determine the angle you would like to show your arrows at for each segment, you could achieve something like this by adding SimpleMarkerSymbols, with the style set to Triangle. If you use a renderer with a rotation expression you can set an attribute on each Graphic to rotate to your desired angle. The code below shows a simple example:
GraphicsOverlay* overlay = new GraphicsOverlay(this);
m_mapView->graphicsOverlays()->append(overlay);
SimpleMarkerSymbol* symbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle::Triangle, Qt::red, 25, this);
Graphic* g1 = new Graphic(Point(0., 0., SpatialReference::wgs84()), this);
g1->attributes()->insertAttribute("ANGLE", 10);
overlay->graphics()->append(g1);
Graphic* g2 = new Graphic(Point(51., 0., SpatialReference::wgs84()), this);
g2->attributes()->insertAttribute("ANGLE", 45);
overlay->graphics()->append(g2);
Graphic* g3 = new Graphic(Point(51., 22., SpatialReference::wgs84()), this);
g3->attributes()->insertAttribute("ANGLE", 28);
overlay->graphics()->append(g3);
SimpleRenderer* renderer = new SimpleRenderer(symbol, this);
renderer->setRotationExpression("[ANGLE]");
overlay->setRenderer(renderer);
If you would like to more complex arrow symbols, there are probably two approaches you could take:
1. Use a PictureMarkerSymbol with an image of your arrow
2. Use a CompositeSymbol to combine several SimpleMarkerSymbols (e.g. a Triangle and a Square) to make the arrow shape
I hope that helps,
Luke
Thank you Luke! That definitely will get me started
Is there any way to determine the angle of a segment from the geometry itself rather than hardcoding it?
Thanks again,
H Nicholas, if you can walk the vertices of the geometry (e.g. using ImmutablePartCollection and so on) you should be able to use the distanceGeodetic method on GeometryEngine (GeometryEngine Class | ArcGIS for Developers ) to determine the azimuth from the start to the end point of your segments.
