How to fix this ?
Please guide me
Below is my pod file desc
source 'https://github.com/CocoaPods/Specs.git'platform :ios, '10.0'use_frameworks!
target 'ArcGISDemo' dopod 'ArcGIS-Runtime-SDK-iOS'end
Thank you for your question! You can take a look at this document to help install the SDK with CocoPods: Install and set up—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
If you're installing the latest iOS Runtime SDK, you'll want to include this line in your pod file:
pod 'ArcGIS-Runtime-SDK-iOS', '100.1'
Let me know if that doesn't work for you.
Mark
# platform :ios, '10.0'
target 'TestArcGIS' do pod 'ArcGIS-Runtime-SDK-iOS', '100.1'end
Not working. Below is output
gautam:TestArcGIS gautamkumarsingh$ pod install
Analyzing dependencies
[!] Unable to satisfy the following requirements:
- `ArcGIS-Runtime-SDK-iOS (= 100.1)` required by `Podfile`
None of your spec sources contain a spec satisfying the dependency: `ArcGIS-Runtime-SDK-iOS (= 100.1)`.
You have either:
* out-of-date source repos which you can update with `pod repo update` or with `pod install --repo-update`.
* mistyped the name or version.
* not added the source repo that hosts the Podspec to your Podfile.
Note: as of CocoaPods 1.0, `pod repo update` does not happen on `pod install` by default.
[!] Automatically assigning platform ios with version 10.3 on target TestArcGIS because no platform was specified. Please specify a platform for this target in your Podfile. See `https://guides.cocoapods.org/syntax/podfile.html#platform`.
[!] Error installing ArcGIS-Runtime-SDK-iOS
[!] /usr/bin/curl -f -L -o /var/folders/_t/15q0ydb10wnbwc9vj6vs44r80000gn/T/d20170822-3830-spxdah/file.zip https://esri.box.com/shared/static/ihda0mduu51ljo4l4u8n1k226qpo7gw0.zip --create-dirs --netrc-optional
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- 0:05:00 --:--:-- 0
curl: (28) Operation timed out after 300541 milliseconds with 0 out of 0 bytes received
Gautam,
The error you're getting suggests to me that your cocoapods repo is likely outdated and does not have the latest pods, that's why it is complaining it cannot find a spec for ArcGIS v100.1. Try running the command `pod repo update` and try again.
Nehru - probably a temporary network/download error. Can you try again and let us know if you're still seeing problems.
Divesh Goyal: Issue resolved, thank you
