Has anyone been able to get the 1.3 FileGDB samples to build on Yosemite? I followed the instructions in the ReadMe file but get an "Undefined symbols for architecture x86_64:" error. Full error below.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C Domains
g++ -fPIC -O3 -m64 -arch x86_64 -W -fexceptions -D_CONSOLE -DUNICODE -D_UNICODE -DUNIX -D_REENTRANT -DFILEGDB_API -D__USE_FILE_OFFSET64 -DUNIX_FILEGDB_API -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -I../../include -I. -m64 -arch x86_64 -L"../../lib" -o ../bin/Domains ./Domains.o -lFileGDBAPI
"FileGDBAPI::Geodatabase::AlterDomain(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
_main in Domains.o
"FileGDBAPI::Geodatabase::CreateDomain(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
_main in Domains.o
"FileGDBAPI::Geodatabase::DeleteDomain(std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> > const&)", referenced from:
_main in Domains.o
"FileGDBAPI::Geodatabase::OpenTable(std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> > const&, FileGDBAPI::Table&)", referenced from:
_main in Domains.o
"FileGDBAPI::OpenGeodatabase(std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> > const&, FileGDBAPI::Geodatabase&)", referenced from:
_main in Domains.o
"FileGDBAPI::Table::AlterField(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced from:
_main in Domains.o
"FileGDBAPI::ErrorInfo::GetErrorRecord(int, int&, std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> >&)", referenced from:
_main in Domains.o
"FileGDBAPI::ErrorInfo::GetErrorDescription(int, std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> >&)", referenced from:
_main in Domains.o
"FileGDBAPI::Geodatabase::GetDomainDefinition(std::__1::basic_string<wchar_t, std::__1::char_traits<wchar_t>, std::__1::allocator<wchar_t> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >&) const", referenced from:
_main in Domains.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: *** [../bin/Domains] Error 1
make: *** [Domains] Error 2
