Are you trying to create your own ClipAnd Ship service or are you using the one on SampleServer. If you are creating your own service, here's a ArcGIS Server help doc that explains how to create your own clip and ship service. The SampleServer service is mangled a bit and we'll fix it as soon as possible. My apologies for the inconvenience. Couple more questions: Are you publishing the map document with a tool layer? Does the tool run successfully on Arcmap?
Are you trying to create your own ClipAnd Ship service or are you using the one on SampleServer.If you are creating your own service, here's a ArcGIS Server help doc that explains how to create your own clip and ship service.The SampleServer service is mangled a bit and we'll fix it as soon as possible. My apologies for the inconvenience.Couple more questions:Are you publishing the map document with a tool layer?Does the tool run successfully on Arcmap?
Error #2044: Unhandled IOErrorEvent:. text=Error #2038: File I/O Error. at widgets.DataExtract::DataExtractWidget/downloadFile() at widgets.DataExtract::DataExtractWidget/alert_ClickHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at mx.core::UIComponent/dispatchEvent() at mx.controls.alertClasses::AlertForm/removeAlert() at mx.controls.alertClasses::AlertForm/clickHandler()
I am having exactly the same problem, Did anyone in this thread manage to come up with a solution?
Janet
