I am using Robert Scheitlin's eSearch Widget on one of my flex apps. When you do a search the search result outline doesn't actually line up on the polygon, it displays to the north of it's actually location. I am using this same widget on a couple other applications without issue, so I can't figure out what is different here that is causing the error. The application with the error is at City of Hastings Parkview Cemeteryâ. My code is
<?xml version="1.0" ?>
<!-- See Enhanced Search Widget XML Configuration.pdf for detailed explanation -->
<configuration>
<layers>
<layer>
<definitionexpression></definitionexpression>
<enableexport>true</enableexport>
<name>Burial Last Name</name>
<url>http://71.8.218.158/arcgis/rest/services/city/Cemetery/MapServer/5</url>
<expressions>
<expression alias="Burial Last Name" textsearchlabel="Search by Burial Last Name:">
<values>
<value prompt="Example: Smith">upper(Lname) like
upper('%[value]%')</value>
</values>
</expression>
</expressions>
<graphicalsearchlabel>Use one of the graphical search tools to select
burial spaces</graphicalsearchlabel>
<spatialsearchlayer>true</spatialsearchlayer>
<titlefield>Last Name</titlefield>
<fields all="false">
<field name="Lname" alias="Last Name" />
<field name="Fname" alias="First Name" />
<field name="MaidenName" alias="Maiden Name" />
<field name="DateOfBirth" alias="Date of Birth" />
<field name="DateOfDeath" alias="Date of Death" />
<field name="SECTION_ID" alias="Section" />
<field name="BLOCK_NUM" alias="Block" />
<field name="LOT_NUM" alias="Lot" />
<field name="SPACE_NUM" alias="Space" />
</fields>
<links />
<zoomscale usegeometry="true" zoompercent="6"></zoomscale>
</layer>
<layer>
<name>Burial First Name</name>
<expressions>
<expression alias="Burial First Name" textsearchlabel="Search by Burial First Name:">
<values>
<value prompt="Example: John">upper(Fname) like
</values>
</expression>
</expressions>
a burial space</graphicalsearchlabel>
<titlefield>First Name</titlefield>
</fields>
<links />
<zoomscale usegeometry="true" zoompercent="6 "></zoomscale>
</layer>
<layer>
<name>Burial Maiden Name</name>
<expressions>
<expression alias="Burial Maiden Name" textsearchlabel="Search by Burial Maiden Name:">
<values>
<value prompt="Example: Smith">upper(MaidenName) like
</values>
</expression>
</expressions>
</fields>
<links />
</layer>
<!--<layer> <definitionexpression></definitionexpression> <enableexport>true</enableexport>
<name>Road Centerlines</name> <url>http://gislap134/ArcGIS/rest/services/Highway/MapServer/5</url>
<expressions> <expression alias="Road Name and Zip" textsearchlabel="Search
by Road Name and Left Zipcode and Right Zip:"> <values> <value prompt="Exmaple:
ANDREW">RD_NAME = '[value]'</value> <value prompt="Exmaple: 36201">AND ZIP_L
= [value]</value> <value prompt="Exmaple: 36201">AND ZIP_R = [value]</value>
</values> </expression> <expression alias="Road Surface" textsearchlabel="Search
by Surface Type:"> <values> <value prompt="Example: Asphalt" field="Surf_Type"
usedomain="true">Surf_Type = [value]</value> </values> </expression> <expression
alias="Open SQL" textsearchlabel="Search by Typing Full SQL:"> <values> <value
prompt="Exmaple: RD_NAME = 'ANDREW' AND ZIP_L = 36201">[value]</value> </values>
</expression> </expressions> <graphicalsearchlabel>Use one of the graphical
search tools to select Roads</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer>
<titlefield>Name</titlefield> <fields all="false"> <field name="Name" gridfield="true"
/> <field name="Classification" gridfield="true" /> <field name="Length_"
numberformat="2|,|." /> <field name="Width" gridfield="true" /> <field name="L_F_ADD"
gridfield="true" /> <field name="L_T_ADD" gridfield="true" /> <field name="R_F_ADD"
gridfield="true" /> <field name="R_T_ADD" gridfield="true" /> <field name="PREFIX"
gridfield="true" /> <field name="PRETYPE" gridfield="true" /> <field name="RD_NAME"
gridfield="true" /> <field name="TYPE" gridfield="true" /> <field name="SUFFIX"
gridfield="true" /> <field name="ZIP_L" gridfield="true" /> <field name="ZIP_R"
gridfield="true" /> </fields> <links> <link alias="View Mon. Ref Sheet">
<![CDATA[http://surveyor.slco.org/gis/map/map_search/mrs_test.cfm?mrspoint={Name}&lat={ZIP_L}&long={ZIP_R}]]>
<icon><![CDATA[assets/images/w_link.png]]></icon> </link> </links> <zoomscale
usegeometry="true" zoompercent="1.6" /> <autoopendatagrid>true</autoopendatagrid>
<relates> <relate id="0" label="ABIMS Bridge" enableexport="true" icon="assets/images/i_hydro.png">
<fields all="true" /> </relate> <relate id="1" label="Average Daily Traffic"
enableexport="true" icon="assets/images/i_flag.png"> <fields all="false">
<field name="Date_" dateformat="MM/DD/YYYY" /> <field name="Road_Name" />
<field name="Road_ID" /> <field name="Location" /> <field name="ADT" sum="true"
sumlabel="ADT Total Count: " /> <field name="Percent_Tr" /> </fields> </relate>
<relate id="2" label="Railroad Crossings" enableexport="true" icon="assets/images/i_folder.png">
<fields all="false"> <field name="Gate" /> <field name="Lights" /> <field
name="Active" /> <field name="At_Grade" /> <field name="Clearance" /> <field
name="Control_Mark" /> </fields> </relate> <relate id="3" label="Signs" enableexport="false"
icon="assets/images/i_lego.png"> <fields all="false"> <field name="Type"
/> <field name="Road_ID" /> <field name="Condition" /> <field name="P_Hyper"
/> <field name="Image_" hyperlinkgridfield="true" hyperlinkaliastext="Get
Sign Image" linksuffix="" linkprefix="" /> <field name="post" /> </fields>
</relate> <relate id="4" label="Guardrails" enableexport="true" icon="assets/images/i_clock.png">
<fields all="false"> <field name="Type" /> <field name="ID" /> <field name="Date_P"
dateformat="MM/DD/YYYY" /> <field name="Date_R" dateformat="MM/DD/YYYY" />
<field name="Type_end_a" /> <field name="Type_start_a" /> <field name="Comments"
/> </fields> </relate> </relates> <queryattachments>false</queryattachments>
</layer> -->
<!-- <layer> <definitionexpression/> <name>Weather Obs</name> <enableexport>true</enableexport>
<url>http://gislap134/ArcGIS/rest/services/Weather_Obs/MapServer/0</url>
<expressions> <expression alias="all" textsearchlabel="blah blah"> <values>
<value prompt="Example: nothing">1=1</value> </values> </expression> </expressions>
<graphicalsearchlabel>Blah Blah</graphicalsearchlabel> <spatialsearchlayer>false</spatialsearchlayer>
<titlefield>Type</titlefield> <fields all="false"> <field name="URL" alias="Website
Link" hyperlinkgridfield="true" linkprefix="http://someWebSite/aspx/web/details.aspx?p_entity="
linksuffix=".aspx"/> <field name="Type" gridfield="true"/> <field name="Temp"
gridfield="true"/> </fields> <links> <link alias="Get Site Info"> <![CDATA[http://someWebSite/aspx/web/details.aspx?p_entity={URL}.aspx]]>
<icon><![CDATA[]]></icon> </link> </links> <zoomscale>5000</zoomscale> </layer> -->
<!-- <layer> <definitionexpression></definitionexpression> <name>Owner
Parcels</name> <enableexport>true</enableexport> <url>http://gislap134/ArcGIS/rest/services/ParcelViewer/MapServer/67</url>
<expressions> <expression alias="Parcel PPIN" textsearchlabel="Search Parcel
by PPIN..."> <values> <value prompt="Example: 1234">PPIN = '[value]'</value>
</values> </expression> </expressions> <graphicalsearchlabel>Use one of the
graphical search tools to select Parcel</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer>
<titlefield>Objectid</titlefield> <fields all="false"> <field name="PPIN"
gridfield="true" /> <field name="NAME" gridfield="true" /> <field name="STREET_ADDRESS"
gridfield="true" /> <field name="USE_CODE" gridfield="true" /> <field name="CALC_ACRES"
gridfield="true" /> <field name="EXEMPTION_CODE1" gridfield="true" /> <field
name="ADDRESS_1" gridfield="true" gridfieldonly="true" /> <field name="ADDRESS_3"
gridfield="true" gridfieldonly="true" /> <field name="PRIOR_TAX_YEAR" gridfield="true"
/> <field name="SALE_DATE" gridfield="true" dateformat="MM/DD/YYYY" useutc="true"/>
<field name="LAST_DEED_BOOK" gridfield="true"/> <field name="LAST_DEED_PAGE"
gridfield="true"/> <field name="ZIPCODE_1" gridfield="true" gridfieldonly="true"/>
<field name="NEIGHBORHOOD" gridfield="true" gridfieldonly="true"/> <field
name="SUBDIVISION" gridfield="true"/> <field name="SALE_PRICE" gridfield="true"
currencyformat="$|2|,|." sum="true" sumlabel="Sales Price: "/> <field name="TOTAL_TRUE"
gridfield="true" currencyformat="$|2|,|." /> <field name="LAND_PRICE" gridfield="true"
currencyformat="$|2|,|." /> <field name="IMPR_PRICE" gridfield="true" currencyformat="$|2|,|."
/> <field name="ADJ_PRICE" gridfield="true" currencyformat="$|2|,|." /> <field
name="OVER_COND" gridfield="true"/> <field name="ADJUSTMENT PRICE" gridfield="true"/>
</fields> <links /> <zoomscale>5000</zoomscale> </layer> -->
</layers>
<spatialrelationships>
<!-- possible spatial relationships esriSpatialRelIntersects | esriSpatialRelContains
| esriSpatialRelCrosses | esriSpatialRelEnvelopeIntersects | esriSpatialRelIndexIntersects
| esriSpatialRelOverlaps | esriSpatialRelTouches | esriSpatialRelWithin currently
unavailable: esriSpatialRelRelation -->
<spatialrelationship>
<name>esriSpatialRelContains</name>
<label>entirely contained in</label>
</spatialrelationship>
<name>esriSpatialRelIntersects</name>
<label>interssected by</label>
<name>esriSpatialRelEnvelopeIntersects</name>
<label>intersected by envelop of</label>
</spatialrelationships>
<bufferunits>
<bufferunit>
<name>UNIT_FOOT</name>
<label>Feet</label>
</bufferunit>
<bufferunit>
<name>UNIT_STATUTE_MILE</name>
<label>Miles</label>
</bufferunit>
<bufferunit>
<name>UNIT_METER</name>
<label>Meters</label>
</bufferunit>
<bufferunit>
<name>UNIT_KILOMETER</name>
<label>Kilometers</label>
</bufferunit>
</bufferunits>
<enabledatagridinteractionwithwidget>true</enabledatagridinteractionwithwidget>
<toleranceforpointgraphicalselection>6</toleranceforpointgraphicalselection><!--
value is in screen pixels -->
<tolerancebydefault>false</tolerancebydefault>
<spatialreference>102003</spatialreference>
<zoomscale>2400</zoomscale>
<geometryservice>http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer</geometryservice>
<csvseparator>,</csvseparator>
<disablebuttons></disablebuttons><!--possible values one or more not all
four search types comma separated text,graphic,spatial,grid,datagrid -->
<defaultselectionoption>textInput</defaultselectionoption><!--possible values
only one graphicalInput or textInput or spatialInput -->
<enabledrawgraphicbutton>true</enabledrawgraphicbutton>
<enablebuffergraphicbutton>true</enablebuffergraphicbutton>
<selectedgraphicaltool></selectedgraphicaltool><!-- possible values are
extent or polygon or mappoint or polyline or nothing -->
<multipartgraphicsearch>false</multipartgraphicsearch>
<floatorfixed disablerelatestabinfixed="false">float</floatorfixed><!--
possible values are fixed and float -->
<relatetooltip>Show Relates</relatetooltip>
<relateicon>widgets/eSearch/assets/images/i_relate.png</relateicon>
<labels>
<bufferusergraphics>Buffer Graphic</bufferusergraphics>
<norelatesfound>No related features found for: </norelatesfound>
<norelatesfoundalerttitle>No Results</norelatesfoundalerttitle>
<addtolerance>Add search tolerance to point selection</addtolerance>
<existingdrawgraphicslabel>Use Existing eDraw Widget Graphics</existingdrawgraphicslabel>
<existingbuffergraphicslabel>Use Existing Point Buffer Widget Graphics</existingbuffergraphicslabel>
<graphicalsearchlabel>Graphical Search</graphicalsearchlabel>
<textsearchlabel>Text Search</textsearchlabel>
<resultslabel>Results</resultslabel>
<layerlabel>Search Layer:</layerlabel>
<layerfieldlabel>Search Layer Field:</layerfieldlabel>
<nolayerlabel>No search layer defined.</nolayerlabel>
<submitlabel>Search</submitlabel>
<pointlabel>Select by Point</pointlabel>
<linelabel>Select by Line</linelabel>
<rectanglelabel>Select by Rectangle</rectanglelabel>
<polygonlabel>Select by Polygon</polygonlabel>
<clearlabel>Clear</clearlabel>
<loadinglabel>Loading...</loadinglabel>
<selectionlabel>Features Selected:</selectionlabel>
<gridresultslabel>Show Results in Grid</gridresultslabel>
<csvdefaultname>Selected Records</csvdefaultname>
<relatescsvdefaultname>Related Records</relatescsvdefaultname>
<exportbtnlabel>Export...</exportbtnlabel>
<export2csvoptionlabel>Export to CSV...</export2csvoptionlabel>
<export2txtoptionlabel>Export to Txt...</export2txtoptionlabel>
<bufferlabel>apply a search distance:</bufferlabel>
<spatialsearchlabel>Spatial search</spatialsearchlabel>
<applybufferlabel>Apply buffer</applybufferlabel>
<searchlayerlabel>Search entities of:</searchlayerlabel>
<enablemultipartsearch>enable multi-part graphics</enablemultipartsearch>
<zoomalllabel>Zoom</zoomalllabel>
<zoomalltip>Zoom to all results</zoomalltip>
<bufferalpha>Adjust buffer alpha</bufferalpha>
<buffercolor>Select buffer color</buffercolor>
</labels>
<symbols>
<simplefillsymbol color="0x448ccb" alpha="0.2">
<outline color="0x448ccb" alpha="0.8" width="2" />
</simplefillsymbol>
<!-- You can have one or the other, either simplemarkersymbol or picturemarkersymbol
defined for your point results NOT BOTH. picturemarkersymbol will override
simplemarkersymbol if you do not have it commented out. -->
<!--<simplemarkersymbol style="square" size="12" color="0xff0000" alpha="0.5"
xoffset="0" yoffset="0" angle="0"> <outline style="solid" color="0x000000"
alpha="1" width="1"/> </simplemarkersymbol> -->
<picturemarkersymbol url="assets/images/i_search.png"
height="30" width="30" xoffset="0" yoffset="0" />
<simplelinesymbol color="0xff0000" alpha="0.8" width="2" />
</symbols>
</configuration>
