It sounds like ArcMap has been configured to perform nonversioned edits on the geodatabase.You can read more about nonversioned edits in the help topic Configuring an ArcMap edit session to perform nonversioned edits.Note that in 10.2.1 you no longer get the chance to discard all edits on stop editing while editing nonversioned data.If you change ArcMap back to the default configuration to edit versioned data, your feature classes in the geodatabase must be 'registered as versioned'.
Ok, I unchecked the "save edits automatically" option and turned off "edit a version of the database with the ability to undo and redo". This is now giving me the option to not accept or accept my edit session which is what I want; however, the undo and redo button still do not work. If I undo or create a polygon that I do not like, I cannot undo the changes. The only time the undo button works is when I am creating a polygon and I want to undo the last vertex. This is a big problem that continues to put stress on having a perfect edit session. The feature layer that I am trying to edit exists in an SDE that contains one versioned feature class, the feature class that I am attempting to edit is non-versioned. What do I need to do to regain the ability to undo and redo edits without having to version a feature class?
If you need real undo/redo then by definition you actually need the capabilities provided by versioning, if only for that reason alone.
