Using Python 3.6.9, I'm making requests with Requests by calling URLs from a text file. I put five of them here, for example. The URLs are all valid.
https://secure.shippingapis.com/ShippingAPI.dll?API=Verify&XML=<AddressValidateRequest USERID="564WILLC0589"><Address><Address1>2001 Gardner Cir W</Address1><Address2></Address2><City>Aurora</City><State>IL</State><Zip5></Zip5><Zip4></Zip4></Address></AddressValidateRequest>
https://secure.shippingapis.com/ShippingAPI.dll?API=Verify&XML=<AddressValidateRequest USERID="564WILLC0589"><Address><Address1>2427 Oakfield Dr</Address1><Address2></Address2><City>Aurora</City><State>IL</State><Zip5></Zip5><Zip4></Zip4></Address></AddressValidateRequest>
https://secure.shippingapis.com/ShippingAPI.dll?API=Verify&XML=<AddressValidateRequest USERID="564WILLC0589"><Address><Address1>2451 Avalon Ct</Address1><Address2></Address2><City>Aurora</City><State>IL</State><Zip5></Zip5><Zip4></Zip4></Address></AddressValidateRequest>
https://secure.shippingapis.com/ShippingAPI.dll?API=Verify&XML=<AddressValidateRequest USERID="564WILLC0589"><Address><Address1>2516 Hillsboro Blvd</Address1><Address2></Address2><City>Aurora</City><State>IL</State><Zip5></Zip5><Zip4></Zip4></Address></AddressValidateRequest>
https://secure.shippingapis.com/ShippingAPI.dll?API=Verify&XML=<AddressValidateRequest USERID="564WILLC0589"><Address><Address1>2623 Shenandoah Ct</Address1><Address2></Address2><City>Aurora</City><State>IL</State><Zip5></Zip5><Zip4></Zip4></Address></AddressValidateRequest><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
What I intend it to do is iterate the list of URLs and request each one in the for loop. Then it prints out the BeautifulSoup object. It looks like an XML when it's printed which is what I want. While debugging, I see it loops once and prints the first URL as desired, but then throws an error at the top of the for loop. I don't see what's wrong with the URL?
<SPAN class="string token">''' (1) putting the URLs one by one in the browser, (2) get the resulting XMLs,
and (3) listing these XMLs as text in a .txt file '''</SPAN>
<SPAN class="keyword token">import</SPAN> requests
<SPAN class="keyword token">from</SPAN> bs4 <SPAN class="keyword token">import</SPAN> BeautifulSoup
txtfile <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Users\jpilbeam\USPSAPIWCHDUpdateAll.txt'</SPAN>
<SPAN class="comment token">#convert text file into a list</SPAN>
<SPAN class="keyword token">with</SPAN> open <SPAN class="punctuation token">(</SPAN>txtfile<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> f<SPAN class="punctuation token">:</SPAN>
x <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>list<SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">(</SPAN>str<SPAN class="punctuation token">.</SPAN>strip <SPAN class="punctuation token">,</SPAN>f<SPAN class="punctuation token">.</SPAN>readlines<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> x<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#Request the URL</SPAN>
response <SPAN class="operator token">=</SPAN> requests<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#see if the URL has been correctly encoded print(r.url)</SPAN>
r_url <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>text
<SPAN class="comment token">#parse the downloaded homepage to get a beautifulsoup object</SPAN>
new_xml <SPAN class="operator token">=</SPAN> BeautifulSoup<SPAN class="punctuation token">(</SPAN>r_url<SPAN class="punctuation token">,</SPAN> features <SPAN class="operator token">=</SPAN> <SPAN class="string token">"xml"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>prettify<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>new_xml<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Error:
[Dbg]>>>
<?xml version="1.0" encoding="utf-8"?>
<AddressValidateResponse>
<Address>
<Address2>
2001 GARDNER CIR W
</Address2>
<City>
AURORA
</City>
<State>
IL
</State>
<Zip5>
60503
</Zip5>
<Zip4>
6213
</Zip4>
</Address>
</AddressValidateResponse>
File "\\gisfile\GISstaff\Jared\Python Scripts\ArcGISPro\CallToFromUSPS_II.py", line 27, in <module>
response = requests.get(i)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 519, in request
prep = self.prepare_request(req)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\sessions.py", line 462, in prepare_request
hooks=merge_hooks(request.hooks, self.hooks),
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\models.py", line 313, in prepare
self.prepare_url(url, params)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\models.py", line 387, in prepare_url
raise MissingSchema(error)
requests.exceptions.MissingSchema: Invalid URL '': No schema supplied. Perhaps you meant http://?
>>> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
