Thank you Tom, I see now the benefits of your suggested method. I have extracted the "9"'s and convert to polygon but I cannot find which tool you are suggesting to use to compare two polygonss to find the changes... (I have an ArcInfo license). I would appreciate if you can tell me the name of the tool if possible?Many thanks Ber
Hi Tom,Many thanks for your reply. I think I may have done something similar - I used raster calculator to subtract each map from my base map to look at the difference between cell values. Do you think the method you suggest will produce different results to what I have done? I see that you have suggested to extract the cells with a value of 9, but i'm still not sure of the difference between the two methods.Many thanks,Ber
