Hi Andreea,Did you ever make in headway with this? I am also trying to find a way to use the geocoding services that come out of the box from ESRI with UK addresses. You would have thought someone would have created a UK address locator by now!ThanksCameron
Hi CameronSorry for this late reply. I haven't checked my emails for ages... Yes, you would have thought so, but the reality is different. I spent lots of time on trying to create my own geocoding service and after loads of trial and error attempts, I have managed to get somewhere. I can proudly say (just because I didn't get any help from ESRI or anyone else and I did it all by myself) that I managed to get a pretty good address locator. It's not perfect and it needs more input, but it's a start. The trouble is that for the last 2 months or so I haven't had the time to look into it, as I had other priorities. We changed our gazetteer software and I need to wait until everything runs smoothly on that side before I spend more time on the locator, but I'm sure that its turn will come soon! 🙂 It's been a while now since I haven't touched it, but from what I can remember I've got to the stage where it finds all the addresses except from one particular situation, i.e.: when you're trying to search for a specific flat within a a block of flats, it returns as 100% matched all the flats within that block of flats. I'll probably need to look more into the scores, but I just couldn't find what exactly needs modifying.I have also tried to create different locators which I can then merge into a composite locator. So...I managed to create a street locator taking the centre point of each street (it would have been great if there was an easy way to modify the one range or two range styles, but as I can see it, there is no easy way of doing it...); I have also created locators for postcodes and towns, which were ok. The postcode locator was a bit tricky, but in the end I managed to modify it so it now recognizes postcodes with or without a space in-between the two parts (e.g. KT17 3EH & KT173EH)Now, it's only a matter of fixing the single house style so that it does exactly what I want it to. Also, once I finish this I want to look into the reverse geocoding as I haven't had the chance to do that at all. Anyway, if you think we can both work on any bit of this geocoding service and get somewhere (2 is always better than 1 🙂 ), please let me know.ThanksAndreea
Hi Danny & CameronSorry, I haven't had much time recently to work on this. If I do manage to progress with it, I will post back here.If it helps, I haven't used OS Addresspoint, but our own gazetteer, as I was told that the first one is not too accurate.Andreea
Hi all;I apologize if this is not the appropriate place for may question, but I'm looking for a answer for days on that. I'm trying to customize a Brazilian address locator style for a specific propose, but my locator doesn't return any field in the Field Map in Create Address Locator window. Looks like my style doesn't require any field, so when I put my reference data a error message appear saying "Too many reference data tables for this style". Moreover, i can't set the inserted reference data as "primary table". The only option is "alias table".I'll attach the XML here. If someone could give a hand on this little question I would be grateful. Best regardsJefferson Ferreira Ferreira
Andreea et aliaPlease try the attached. A UK style is still in progress.Regards
Hi there;Andreea, thank you very much for your interest in help me. I was working on that a month.Besides the question of the fields were not appear in Create Address Locator window, i need to put a reference data with 4 fields of house number on each line segment: Left from, left to, and so on. But I'm not sure where declare that issue in xml file. I emphasize the Brazilian address style is composed by a prefix (av, st,...) street name and number.If you, or someone, could help I'll be grateful.Regards,Jefferson Ferreira Ferreira
Hi all,
I am new to this and I am actually stuck at the part for reference data. May I know where do you guys get the reference data?
Thanks!
Sorry if this sound like a stupid question.
jazzgoh12 This is a very old post from 2011. I'll suggest that you post your question, as a new Thread, including all the details--
What are you trying to do?
What have you already tried?
What resources have you checked?etc
The problem with starting a new thread, is that people can't see how long ESRI have ignored adding basic functionality into their product, relying on their users (who don't pay a small sum for their licenses!) to fix it for them. The fact that I have had to search the community forum, for a UK address locator and a scalebar showing the current scale on a "World Leading" GIS system, is shocking!
Don't you just hate it when you have a problem ,Google it, find a forum that looks interesting, only to find you've been here before and posted in it and that previous version of me has made more progress that today's version of me?
Surely, someone has found a way to do a simple UK locator - all I want is a simple wild card search on a single field!
