Having not yet upgraded an existing WAB Dev Edition install, is there a process/workflow that I should follow to upgrade existing sites built with a previous version?
Eric,
you can import an older version WebApp via the following:
Create and import app—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
Tim
I upgraded my apps using the instructions above and it worked well. It will copy over any custom widgets, but you'll still have to make any necessary customizations that you may have made to any files that aren't in the custom widget folder.
I noticed that the instructions on this page Upgrade apps—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
are just slightly wrong. In step 4 where it says "type node ....", you'll want to use node_64 or node_86 depending on whether you have a 64 bit or 32 bit system.
Also Upgrade apps—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers which you would probably see in the TOC on the link Tim provided.
and, although I need to review/update this.. Tips (LocalLayer widgets) for more customization and Updating (may help with others too)
Thanks Tim!
