The publishData() function won't work inside setTimeout() in my custom widget - returns error: this.publishData() is not a function. But this.publishData() works fine alone. How to get this.publishData() work inside setTimeout()?
Xuan,
Your issue is going to be a scope issue. The "this" object inside your setTimeout function is not scoped to the widget so this.publishData is not a function. You need to hitch your setTimeout function using lang.hitch.
<SPAN class="token function">setTimeout</SPAN><SPAN class="punctuation token">(</SPAN>lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">publishData</SPAN><SPAN class="punctuation token">(</SPAN>yourdata<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">200</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Sharp answer, thank you!
