<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title> Maps Toolbar </title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad: true } </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"> </script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.toolbars.edit"); dojo.require("dijit.form.Button"); dojo.require("dijit.Menu"); dojo.require("esri.undoManager"); var map, editToolbar, undoManager; var oldGraphic, currentGraphic; function init() { var startExtent = new esri.geometry.Extent({"xmin":-10527519,"ymin":3459600,"xmax":11408073,"ymax":13047861,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: startExtent, wrapAround180:true }); dojo.connect(map, "onLoad", createToolbar); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); map.addLayer(basemap); undoManager = new esri.UndoManager(); buildOperations(); } function buildOperations(){ dojo.declare('operations.graphics.applyEdit', esri.OperationBase, { label: 'Apply Edit', constructor: function (parameters) { }, performUndo: function () { var test = map.graphics.graphics; for (var i = 0; i < test.length; i++) { if (test.geometry == currentGraphic.geometry) { test.setGeometry(oldGraphic.geometry); editToolbar.refresh(); } } }, performRedo: function () { for (var i = 0; i < map.graphics.length; i++) { if (map.graphics.geometry == oldGraphic.geometry) { map.graphics.setGeometry(currentGraphic.geometry); editToolbar.refresh(); } } } }); } function createToolbar(map) { dojo.connect(dijit.byId('map'), 'resize', resizeMap); addGraphics(); editToolbar = new esri.toolbars.Edit(map); //Activate the toolbar when you click on a graphic dojo.connect(map.graphics, "onClick", function(evt) { dojo.stopEvent(evt); activateToolbar(evt.graphic); }); //deactivate the toolbar when you click outside a graphic dojo.connect(map,"onClick", function(evt){ editToolbar.deactivate(); }); } function addGraphics() { //add pre-defined geometries to map var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])); var polylineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 3); var polyline = new esri.geometry.Polyline({"paths":[[[-12484306.95575803,7244028.536719631],[-7318386.8361340165,10061803.147423638],[-3013453.403114006,10727111.04161764]]],"spatialReference":{"wkid":102100}}); var polygon = new esri.geometry.Polygon({ "rings": [ [ [-4226661.916056009, 8496372.808143634], [-3835304.3312360067, 8731187.359035634], [-2269873.991956003, 9005137.668409634], [-1213208.5129420012, 8613780.083589634], [-1017529.7205320001, 8065879.464841632], [-1213208.5129420012, 7478843.087611631], [-2230738.233474003, 6891806.710381631], [-2935181.8861500043, 6735263.6764536295], [-3522218.263380006, 6891806.710381631], [-3952711.606682008, 7165757.01975563], [-4265797.674538009, 7283164.295201631], [-4304933.433020009, 7635386.121539632], [-4304933.433020009, 7674521.880021632], [-4226661.916056009, 8496372.808143634] ] ], "spatialReference": { "wkid": 102100 } }); var triangle = new esri.geometry.Polygon({ "rings": [ [ [2426417.02588401, 8535508.566625634], [4304933.433020014, 12292541.380897645], [6183449.840156019, 8535508.566625634], [2426417.02588401, 8535508.566625634] ] ], "spatialReference": { "wkid": 102100 } }); map.graphics.add(new esri.Graphic(polyline, polylineSymbol)); map.graphics.add(new esri.Graphic(polygon, polygonSymbol)); map.graphics.add(new esri.Graphic(triangle, polygonSymbol)); } function activateToolbar(graphic) { var tool = 0; if (dijit.byId("tool_move").checked) { tool = tool | esri.toolbars.Edit.MOVE; } if (dijit.byId("tool_scale").checked) { tool = tool | esri.toolbars.Edit.SCALE; } if (dijit.byId("tool_rotate").checked) { tool = tool | esri.toolbars.Edit.ROTATE; } editToolbar.activate(tool, graphic); dojo.connect(map, 'onClick', dojo.hitch(this, this.handleMapClick)); dojo.connect(editToolbar, 'onGraphicFirstMove', handleGraphicEdit); dojo.connect(editToolbar, 'onScaleFirstMove', handleGraphicEdit); dojo.connect(editToolbar, 'onRotateFirstMove', handleGraphicEdit); dojo.connect(editToolbar, 'onGraphicMoveStop', handleGraphicEditStop); dojo.connect(editToolbar, 'onScaleStop', handleGraphicEditStop); dojo.connect(editToolbar, 'onRotateStop', handleGraphicEditStop); } function handleGraphicEdit(graphic){ oldGraphic = new esri.Graphic(graphic.geometry, graphic.symbol); } function handleGraphicEditStop(graphic){ currentGraphic = new esri.Graphic(graphic.geometry, graphic.symbol); var operation = new operations.graphics.applyEdit({ graphics: map.graphics, currentGraphic: currentGraphic, oldGraphic: oldGraphic }); undoManager.add(operation); } function resizeMap() { //resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in //the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_guidelines.htm var resizeTimer; clearTimeout(resizeTimer); resizeTimer = setTimeout(function() { map.resize(); map.reposition(); }, 500); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:'false'" style="width:100%; height:100%;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:58px;text-align:left;font-weight:bold;font-size:14px;color:#400D12;"> <span>Specify editing options then click a graphic to edit the shape. Click outside the graphic to deactivate the toolbar.</span><br /> <div id="tool_move" data-dojo-type="dijit.form.ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Move</div> <div id="tool_scale" data-dojo-type="dijit.form.ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Scale</div> <div id="tool_rotate" data-dojo-type="dijit.form.ToggleButton" data-dojo-props="checked:'true', iconClass:'dijitCheckBoxIcon'">Rotate</div> <button data-dojo-type="dijit.form.Button" data-dojo-props="onClick:function(){undoManager.undo()}">Undo</button> <button data-dojo-type="dijit.form.Button" data-dojo-props="onClick:function(){undoManager.redo()}">Redo</button> </div> <div id="map" data-dojo-type="dijit.layout.ContentPane" style="border:solid 2px cornflowerblue;margin:5px;" data-dojo-props="region:'center'"> </div> </div> </body> </html>
<!doctype html> <html lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Editing Points with Undo/Redo</title> <!-- include dojo theme --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; background:#fff; } #header{ border: solid 1px #232416; color:#453823; font-weight:600; font-size:14px; height:40px; } #map{ border: solid 1px #232416; padding:0; } #leftPane{ width:200px; border:none; } .templatePicker { border:solid 2px #232416 !important; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} .esriAttributeInspector .atiRichTextField .dijitEditorIFrameContainer{ height:60px; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad:true }; </script> <!-- reference ArcGIS JavaScript API --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script> <script type="text/javascript"> dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.BorderContainer"); dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("esri.dijit.editing.editOperation"); dojo.require("esri.undoManager"); var map, resizeTimer, myEditor; function init() { // Specify your proxy URL esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx"; esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://sampleserver3.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer"); var initialExtent = new esri.geometry.Extent({"xmin":-13114358,"ymin":4069927,"xmax":-13097981,"ymax":4077246,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: initialExtent }); dojo.connect(map, "onLoad", function() { dojo.connect(dijit.byId('map'), 'resize', function() { resizeMap(); }); }); dojo.connect(map, "onLayersAddResult", initEditor); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var pointsOfInterest = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); dojo.connect(pointsOfInterest, 'onLoad', function(poi) { poi.setSelectionSymbol(new esri.symbol.SimpleMarkerSymbol('circle', 32, null, new dojo.Color([0, 0, 0, 0.25]))); }); map.addLayers([pointsOfInterest]); } function initEditor(results) { var layers = dojo.map(results, function(result) { var fieldInfos= dojo.map(result.layer.fields,function(field){ if(field.name === 'description'){ return {'fieldName': field.name,'label':'Details',stringFieldOption:esri.dijit.AttributeInspector.STRING_FIELD_OPTION_RICHTEXT,richTextPlugins:['undo','redo','bold', 'italic']} } else{ return {'fieldName': field.name,'label':field.alias} } }); return {featureLayer:result.layer,'fieldInfos':fieldInfos} }); var templateLayers = dojo.map(results,function(result){ return result.layer; }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, rows: 'auto', columns: 'auto', style:'height:98%;width:98%;' },'templatePickerDiv'); templatePicker.startup(); // Create Editor and specify an undoManager var undoManager = new esri.UndoManager(); var settings = { templatePicker: templatePicker, map: map, layerInfos:layers, toolbarVisible: false, enableUndoRedo: true, undoManager: undoManager } var params = {settings: settings}; myEditor = new esri.dijit.editing.Editor(params); myEditor.startup(); map.infoWindow.resize(275,220); dojo.connect(dojo.byId('undo'), 'onclick', function(click) { if ( myEditor.undoManager.canUndo ) { myEditor.undoManager.undo(); console.log('called undo'); } else { alert('Nothing to undo.'); } }); dojo.connect(dojo.byId('redo'), 'onclick', function(click) { if ( myEditor.undoManager.canRedo ) { myEditor.undoManager.redo(); console.log('called redo'); } else { alert('Nothing to redo.'); } }); } //Handle resize of browser function resizeMap(){ clearTimeout(resizeTimer); resizeTimer = setTimeout(function(){ map.resize(); map.reposition(); }, 500); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="gutters:true, design:'sidebar'" style="width:100%;height:100%;"> <div data-dojo-type="dijit.layout.ContentPane" id="header" data-dojo-props="region:'top'"> Fire Map <div class="undoButtons"> <button id="undo" data-dojo-type="dijit.form.Button"> Undo </button> <button id="redo" data-dojo-type="dijit.form.Button"> Redo </button> </div> </div> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> <div id="leftPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'"> <div id="templatePickerDiv"></div> </div> </div> </body> </html>
