I am trying to find the correct way to find the min and max values of a layer in ArcGIS. There are approx. 80 feeders and i have written a python script to show only 1 feeder at a time for that layer. What statement in python would i use to calculate this?
Thanks for any help
Since the ArcPy mapping modules are significantly different between ArcMap and ArcGIS Pro, it is always good to specify what product you are using when talking about layers in ArcGIS. Since you tagged it Python 2.7, I will assume you are working with ArcMap. I suggest you take a look at Layer—Help | ArcGIS for Desktop if you haven't already.
Typically when working with layers, people commonly talk about xmin, xmax, ymin, and ymax in terms of the layer's extent. I would use the getExtent method to return an Extent object and then access the max and min properties from it.
thanks a lot. i will look at how to implement the getExtent.
