[INDENT]You must first load the �??os�?? Python library (using: �??import os�??) at the beginning of your Python session. To call GME from the command line you use the following generic syntax: os.system(�?�path\\SEGME.exe commands�?�)[/INDENT]
snappoints(in, snap, out, tol, [where]);in --> the input point data source snap--> the input feature source to which points are snapped out--> the output point data source tol--> the maximum snap distance in coordinate system units [where] the selection statement that will be applied to the point feature data source to identify a subset of points to process (see full Help documentation for further details)Example 1: snappoints(in="C:\data\locs.shp", snap="C:\data\roads.shp", out="C:\data\snappedlocs.shp", tol=5000);
#Import library modules import os arcpy # Read parameter values # 1 in --> the input point data source # 2 snap--> the input feature source to which points are snapped # 3 out--> the output point data source # 4 tol--> the maximum snap distance in coordinate system units in = arcpy.GetParameterAsText(0) snap = arcpy.GetParameterAsText(1) out = arcpy.GetParameterAsText(2) tol = arcpy.GetParameterValue(3) #Loading GME and running GME-Tool os.system(�?�path\\SEGME.exe -c snappoints(in, snap, out, tol)�?�)
# --------------------------------------------------------------------------- # gis_Test1.py # Description: Snap Point to Feature (Spatial Ecology) # --------------------------------------------------------------------------- import os import arcpy #Read Parameters #1 in --> the input point data source #2 snap --> the input feature source to which points are snapped #3 out --> the output point data source #4 tol --> tbe maximum snap distance in coordinate system units inpoint = arcpy.GetParametersAsText(0) snap = arcpy.GetParametersAsText(1) outpoint = arcpy.GetParametersAsText(2) tol = arcpy.GetParametersAsValue(3) os.system("C:\\Program Files (x86)\\SpatialEcology\\GME\\SEGME.exe -c snappoints(in=\\\"%s\\\", snap=\\\"%s\\\", out=\\\"%s\\\", tol=%s);" %(inpoint, snap, outpoint, tol))
# --------------------------------------------------------------------------- # gis_Test1.py # Description: Snap Point to Feature (Spatial Ecology) # --------------------------------------------------------------------------- import os import arcpy #Read Parameters #1 inpoint --> the input point data source #2 snap --> the input feature source to which points are snapped #3 outpoint --> the output point data source #4 tol --> tbe maximum snap distance in coordinate system units inpoint = arcpy.GetParameterAsText(0) snap = arcpy.GetParameterAsText(1) outpoint = arcpy.GetParameterAsText(2) os.system("C:\\Program Files (x86)\\SpatialEcology\\GME\\SEGME.exe -c snappoints(in=\\\"%s\\\", snap=\\\"%s\\\", out=\\\"%s\\\", tol=500);" %(inpoint, snap, outpoint))
