I am using the testing data in a file deodatabase. It is not a geometric network. The features are about 2000 to flip at one time. I use code exactly like this.
I am trying to flip selected pipelines using stand-alone python window. Below are the steps I used: 1). line join attributes from other tables (MakeFeatureLayer, AddJoin); 2). select lines based on the joined attributes (SelectLayerByAttribute); 3). remove joins (RemoveJoin); 4). flip line on the selected lines (FlipLine_edit with or without MakeFeatureLayer after the selection).It is shown the same error: ERROR 999999: Error executing function.Workspace or data source is read only.Workspace or data source is read only.Failed to execute (FlipLine).Anyone has any solution?Thanks.
import arcpy try: arcpy.FlipLine_edit(inFeatures) except Exception, e: # If an error occurred, print line number and error message import traceback, sys tb = sys.exc_info()[2] print "Line %i" % tb.tb_lineno print e.message
