OK, so far for posting code without testing it ...
I created a small test dataset, consisting of a DEM (integer raster) and some random polygons. During the test a number of errors in the code were revealed. These are corrected in the code below:
def GetPixelValueForPercentile(dctper, percentile): """will return last pixel value where percentile LE searched percentile.""" for k in sorted(dctper.keys()): perc = dctper if perc <= percentile: pix_val = k else: break return pix_val def FieldExist(featureclass, fieldname): """Check if field exists""" import arcpy fieldList = arcpy.ListFields(featureclass, fieldname) return len(fieldList) == 1 import arcpy # settings ras = r"D:\Xander\tmp\ras.gdb\DEMsmpro" fc = r"D:\Xander\tmp\ras.gdb\pols" # ras = r"C:\Path\To\Folder\Or\Geodatabase\With\Raster" # fc = r"C:\Path\To\Folder\Or\Geodatabase\With\PolygonFeatureclass" lst_perc = [2, 5, 10, 90, 95, 98] # list of percentiles to be calculated fld_prefix = "Perc_" arcpy.env.workspace = "IN_MEMORY" arcpy.env.overwriteOutput = True # add fields if they do not exist in fc # be aware, field that exist will be overwritten! print "filling field list and adding fields" flds = [] for perc in lst_perc: fld_perc = "{0}{1}".format(fld_prefix, perc) flds.append(fld_perc) if not FieldExist(fc, fld_perc): arcpy.AddField_management(fc, fld_perc, "LONG") print "flds={0}".format(flds) # Enable Spatial analyst arcpy.CheckOutExtension("Spatial") # loop through polygons print "loop through polygons" flds.append("SHAPE@") i = 0 with arcpy.da.UpdateCursor(fc, flds) as curs: for row in curs: i += 1 print "Processing polygon: {0}".format(i) polygon = row[flds.index("SHAPE@")] lst_parts = [] if polygon.partCount == 1: for part in polygon: for pnt in part: x, y = pnt.X, pnt.Y lst_parts.append(arcpy.Point(x, y)) else: for part in polygon: lst_crds = [] for pnt in part: x, y = pnt.X, pnt.Y lst_crds.append(arcpy.Point(x, y)) lst_parts.append(lst_crds) print " - lst_parts={0}".format(lst_parts) # Execute ExtractByPolygon (you can't send the polygon object) print " - ExtractByPolygon..." ras_pol = arcpy.sa.ExtractByPolygon(ras, lst_parts, "INSIDE") outname = "ras{0}".format(i) ras_pol.save(outname) print " - saved raster as {0}".format(outname) # create dictionary with value vs count print " - fill dict with Value x Count" flds_ras = ("VALUE", "COUNT") dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(outname, flds_ras)} # calculate number of pixels in raster print " - determine sum" cnt_sum = sum(dct.values()) print " - sum={0}".format(cnt_sum) # loop through dictionary and create new dictionary with val vs percentile print " - create percentile dict" dct_per = {} cnt_i = 0 for val in sorted(dct.keys()): cnt_i += dct[val] dct_per[val] = cnt_i / cnt_sum # loop through list of percentiles print " - iterate perceniles" for perc in lst_perc: # use dct_per to determine percentiles perc_dec = float(perc) / 100 print " - Perc_dec for is {0}".format(perc_dec) pixval = GetPixelValueForPercentile(dct_per, perc_dec) print " - Perc for {0}% is {1}".format(perc, pixval) # write pixel value to percentile field print " - Store value" fld_perc = "{0}{1}".format(fld_prefix, perc) row[flds.index(fld_perc)] = pixval # update row print " - update row" curs.updateRow(row) # return SA license arcpy.CheckInExtension("Spatial")
What you get are a number of fields in your polygon featureclass:
When you add some labels to display the values, you'll see that they actually correspond to the areas:
So Todd, I hope this will work for you.
Kind regards,
Xander
I am looking for an analogous method to Zonal Statistics that is able to generate user-defined percentiles (such as the 5th and 95th percentile) of the input raster data.
You then analyze your sliced raster with Zonal Statistics As Table to get the min and max for each class.
It may be that my slice raster was not generated properly (attribute table shown below). It looks like it returned the number of cells in each class, which are all about the same since I used equal area classes.
I don't see how to analyze this sliced raster with zonal statistics to generate a table of percentiles?
I'm sorry Todd - still working on how to track threads in this new system, hence no reply til now.
If you ask for 20 classes from the Slice tool with the equal area option, the first class is the 5th percentile, ie VALUE times 5 (100 / 20).
If you want the percentile values (breaks), you can run Zonal Statistics As Table using the sliced raster for zones and the input to the slice for values.
Hi Todd,
Maybe a little Python can help: Look at the code below:
def GetPixelValueForPercentile(dctper, percentile): """will return last pixel value where percentile LE searched percentile.""" for k in sorted(dctper.keys()): perc = dctper if perc <= percentile: pix_val = k else: break return pix_val import arcpy # path to raster (has to be integer!) ras = r"C:\Path\To\Folder\Or\Geodatabase\With\Raster" # create dictionary with value vs count flds = ("VALUE", "COUNT") dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(ras, flds)} # calculate number of pixels in raster cnt_sum = sum(dct.values()) dct_per = {} cnt_i = 0 # loop through dictionary and create new dictionary with val vs percentile for val in sorted(dct.keys()): cnt_i += dct[val] dct_per[val] = cnt_i / cnt_sum # use dct_per to determine percentiles perc = 0.05 # (5%) pixval = GetPixelValueForPercentile(dct_per, perc) print "Found for percentile {0}, pixel value {1} with real percentile {2}".format(perc, pixval, dct_per[pixval]) perc = 0.95 # (95%) pixval = GetPixelValueForPercentile(dct_per, perc) print "Found for percentile {0}, pixel value {1} with real percentile {2}".format(perc, pixval, dct_per[pixval])
It will return the following information:
>> Found for percentile 0.05, pixel value 401 with real percentile 0.049861616298 >> Found for percentile 0.95, pixel value 2350 with real percentile 0.949769065993
The code requires that your raster is of type integer (to make sure it has an attribute table with pixelvalue and count.
This is what happens in the code:
Hope this is of any use.
Kind regards, Xander
Thanks for the Python code for percentiles from a raster Xander.
In my situation, I have multiple polygons that occur in various locations across a raster. I would like to generate the percentile statistics from the various portions of the raster that overlap with each individual polygon. Then, join those statistics with a unique row ID in the polygon layer.
I am essentially in need of "Zonal Statistics as Table" with the ability to include percentile statistics along with Minimum, Mean, and Maximum.
How can this be incorporated via Python?
One option is that you write a loop through the polygon (Update cursor) to do this for each polygon:
In case there is no overlap between the polygons, you could do the following:
Not sure which option will be the fastest.
Now to throw in some code (which by the way I did not test), it should look something like this:
def GetPixelValueForPercentile(dctper, percentile): """will return last pixel value where percentile LE searched percentile.""" for k in sorted(dctper.keys()): perc = dctper if perc <= percentile: pix_val = k else: break return pix_val def FieldExist(featureclass, fieldname): """Check if field exists""" import arcpy fieldList = arcpy.ListFields(featureclass, fieldname) return len(fieldList) == 1 import arcpy # settings ras = r"C:\Path\To\Folder\Or\Geodatabase\With\Raster" fc = r"C:\Path\To\Folder\Or\Geodatabase\With\PolygonFeatureclass" lst_perc = [2, 5, 10, 90, 95, 98] # list of percentiles to be calculated fld_prefix = "Perc_" arcpy.env.workspace = "IN_MEMORY" # add fields if they do not exist in fc # be aware, field that exist will be overwritten! flds = [] for perc in lst_perc: fld_perc = "{0}{1}".format(fld_prefix, perc) flds.append(fld_perc) if not FieldExist(fc, fld_perc): arcpy.AddField_management(fc, fld_perc, "LONG") # Enable Spatial analyst arcpy.CheckOutExtension("Spatial") # loop through polygons flds.append("SHAPE@") with arcpy.da.UpdateCursor(fc, flds) as curs: for row in curs: polygon = row[flds.index("SHAPE@")] lst_parts = [] for part in polygon: lst_crds = [] for crdpair in part: x, y = crdpair[0], crdpair[1] lst_crds.append(arcpy.Point(x, y)) lst_parts.append(lst_crds) # Execute ExtractByPolygon ras_pol = arcpy.sa.ExtractByPolygon(ras, polygon, "INSIDE") # not sure if ras_pol should be saved... # create dictionary with value vs count flds_ras = ("VALUE", "COUNT") dct = {row[0]:row[1] for row in arcpy.da.SearchCursor(ras_pol, flds_ras)} # calculate number of pixels in raster cnt_sum = sum(dct.values()) # loop through dictionary and create new dictionary with val vs percentile dct_per = {} cnt_i = 0 for val in sorted(dct.keys()): cnt_i += dct[val] dct_per[val] = cnt_i / cnt_sum # loop through list of percentiles for perc in lst_perc: # use dct_per to determine percentiles prec_dec = float(perc) / 100 pixval = GetPixelValueForPercentile(dct_per, perc) # write pixel value to percentile field fld_perc = "{0}{1}".format(fld_prefix, perc) row[flds.index(fld_perc)] = pixval # update row curs.updateRow(row) # return SA license arcpy.CheckInExtension("Spatial")
If you run into problems, let me know. Maybe you can throw in a piece of your data to test the code.
Thanks for this. An approach that you might consider is to use rastertonumpyarray rather than looping through the extracts for each polygon. In my kludge to do something similar, actually wanted cumulative frequency curves, I extracted using rastertonumpyarray, flattened the array, sorted it ascending and then was working on calculating the percentiles when I said, "heck with it" and sent it all to Excel to finish. But the processing might be more efficient working in numpy.
Hi All
Given this is over three years old ... is this still the best way to calculate a percentile as zonal stats still doesn't?
I haven't seen any new tool that does this. However, it might be a good thing to create an idea and upvote it.
Done
https://community.esri.com/ideas/14354
And upvoted...
