I have a simple application set up where the user must use a button to activate delete features. If the button is checked, the user can left click on the feature and delete. If the button is unchecked, the user cannot delete features using the left mouse click. The problem is, that I have multiple feature layers within the application and I want to be able to delete features from each feature layer. Currently, I can only delete from one feature layer.How can I delete features from each feature layer using the same button?Here is my current application code:<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Delete Feature</title> <link rel="stylesheet" href="http://localhost/arcgis_js_api/library/3.5/jsapi/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://localhost/arcgis_js_api/library/3.5/jsapi/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; } #map{ padding:0px; border:solid 2px #1A84AD; -moz-border-radius: 4px; border-radius: 4px; } #rightPane{ border:none; width:300px; </style> <script>var dojoConfig = { parseOnLoad:true };</script> <script src="http://localhost/arcgis_js_api/library/3.5/jsapi/init.js"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("dijit.Menu"); dojo.require("dijit.form.Button"); dojo.require("esri.dijit.editing.TemplatePicker-all"); dojo.require("esri.dijit.editing.editOperation"); //VARIABLES var map; //var undoManager; // FUNCTION INITIALIZE function init() { //specify the number of undo operations allowed using the maxOperations parameter //undoManager = new esri.UndoManager({ maxOperations: 10 }); // PROXY PAGE CONFIGURATION esri.config.defaults.io.proxyUrl = "http://localhost/Proxy/proxy.ashx"; // MAP EXTENT DEFINITION var initialExtent = new esri.geometry.Extent({xmin: 2089355.926669004,ymin: 212687.42173663445,xmax: 2198005.6105589992,ymax: 303894.02712456253,"spatialReference": {"wkid": 2267} }); // MAP map = new esri.Map("map", { extent: initialExtent }); //CONNECT MAP WITH DELETE FEATURE EDITING FUNCTIONALITY dojo.connect(map, "onLayersAddResult", EditingDeleteFeature); // FEATURE LAYERS FOR EDITING var publictreeinventory = new esri.layers.FeatureLayer("http://localhost/arcgis/rest/services/UrbanForestry/PublicTreeInventorySDE02/FeatureServer/0",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var emergencymanagement = new esri.layers.FeatureLayer("http://localhost/arcgis/rest/services/EmergencyManagement/EmergencyManagementSDE02/FeatureServer/0",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var plantingsites = new esri.layers.FeatureLayer("http://localhost/arcgis/rest/services/UrbanForestry/PublicTreeInventorySDE02/FeatureServer/1",{ //id: plantingsitesID, mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([publictreeinventory, emergencymanagement, plantingsites]); } // DELETE TOOL function EditingDeleteFeature(results) { var deleteFeatureslLayer = results[0].layer; var layers = dojo.map(results, function(result) { return result.layer; }); // Ctrl+click to delete features and add this delete operation to undomanager dojo.connect(deleteFeatureslLayer, "onClick", function(evt) { dojo.stopEvent(evt); // DELETE FEATURE IS DELETE BUTTON IS CHECKED (ACTIVE) if (dijit.byId("tool_delete").checked) { deleteFeatureslLayer.applyEdits(null, null, [evt.graphic], function() { operation = new esri.dijit.editing.Delete({ featureLayer: deleteFeatureslLayer, deletedGraphics: [evt.graphic] }); }); } }); } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="gutters:true, design:'sidebar'" style="width:100%;height:100%;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> <div id="rightPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'"> <div id="tool_delete" data-dojo-type="dijit.form.ToggleButton" data-dojo-props="checked:false, iconClass:'dijitCheckBoxIcon'">Delete</div> <div class='instructions'> <ul style="list-style:none;padding-left:4px;"> <li><b>To delete feature:</b> <br> Click on the Delete button to check and activate delete features. Left mouse click on feature to delete. Uncheck Delete button when finished.</li> </ul> </div> </div> </div> </body> </html>
