I have a table containing some calculated results and a feature class with 4 text fields that I want to bring into the results table based on a shared ID field (Long). Both contain just fewer than 60,000 rows/features and both have indexes on the ID field used for the join.
If I do this using the Join Field tool in ArcMap 10.2.2 the process takes over 50 minutes. This is insane for a join on ~60k rows.
As a comparison I can do the process manually in ArcMap in under 4 minutes by creating new fields, joining data and calculate fields.
If I use the Add Join tool to join all fields the process takes 11 seconds. However, this brings in a whole heap of fields that I am not interested in.
Additional notes: The process is to be run from within a .Net application so the manual process is not an option. The PC is an 8 core machine, the CPU usage sits at around 12% and there is about 10GB of available memory.
Why is Join Field so incredibly slow?
