private bool fetchAndPassBackToClient(System.Net.WebResponse serverResponse, HttpResponse clientResponse, bool ignoreAuthenticationErrors) { if (serverResponse != null) { if (serverResponse.ContentType == "application/vnd.ogc.wms_xml") clientResponse.ContentType = "text/xml"; else clientResponse.ContentType = serverResponse.ContentType; using (Stream byteStream = serverResponse.GetResponseStream()) { ....
I just encountered this problem as well, and fortunately found this thread that clarified what the cause was. Since I need to use a proxy for the GetCapabilities request, I've just edited the proxy so that a ContentType of 'application/vnd.ogc.wms_xml' with 'text/xml' before the response is returned. If you're using the current DotNet version of the resource-proxy Esri has hosted on GitHub ( https://github.com/Esri/resource-proxy), you can make this change near the start of the fetchAndPassBackToClient method in the proxy.ashx file (around line 293): private bool fetchAndPassBackToClient(System.Net.WebResponse serverResponse, HttpResponse clientResponse, bool ignoreAuthenticationErrors) { if (serverResponse != null) { if (serverResponse.ContentType == "application/vnd.ogc.wms_xml") clientResponse.ContentType = "text/xml"; else clientResponse.ContentType = serverResponse.ContentType; using (Stream byteStream = serverResponse.GetResponseStream()) { ....
