You can try to first bring your unextruded polygon into arcscene, open up the properties of the polygon, and set your extrusion there. After it's set, and with ArcScene still open, you can run the sun shadow volume tool.
Hello everyone, I had the same problem with Syamsuri Satria.
I have try to input the extruded polygon or fgdb file but there is the same error (999999) and no result given out.
Is there any necessary features or layer I should use for the sun shadow volume tool?Anyone can help me to solve it?Thanks a lot!
Ying
Hello...Help me!! i have problems about using tool "Sun Shadow Volume" In ArcScene 10.1.
i use feature (shp) extruded 3D layer
then i use tool "Sun Shadow Volume" with data :
- Start date and time : 1/22/2015 6:00:00 AM
- End date and time : 1/22/2015 5:00:00 PM
- Iteration interval (optional) : 1
- Iteration unit (optional) : hours
but always it don't succeed..show the words "Error 999999"
Thanks all
Syamsuri Satria
