How can I use systemList variable with several defined types with arcpy.da.SearchCursor? Currently, I have it looking at '009' but I would like it to find every system defined in systemList.
import arcpy
fc = 'Database Connections\SDE.sde\NEO_1.SDE.P_PipeSystem\NEO_1.SDE.P_Meters'
field = 'SYSTEMNUMBER'
systemList = ["009", "10", "12", "13", "21", "22", "27", "27A", "27B", "27C", "30", "31", "33", "34", "35", "36"]
cursor = arcpy.da.SearchCursor(fc, (field, "SYSTEMNUMBER"), """SYSTEMNUMBER = '009'""")
count = 0
# For each row print the
for row in cursor:
# Print the name of the gas systems
#print(row[1])
#result = arcpy.GetCount_management(fc)
#print('{} has {} records'.format(row[1], result[0]))
count += 1
print('{} has {} records'.format(row[1],count))
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
