How to bind fetched items from ItemFileReadStore to a table td vertically not datagrid
Question asked by Sadanandachar B on Jun 16, 2016
Like • Show 0 Likes0 Comment • 0
Hi All,
I am binding items to data grid table as shown below,
function executeIdentifyTask(geom) {
//clear the graphics layer
map.graphics.clear();
// var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([151, 249, 0, .80]), 3), new dojo.Color([151, 249, 0, 0.45]));
symbol = new esri.symbol.SimpleMarkerSymbol();
symbol.setSize(10);
symbol.setColor(new dojo.Color([255, 255, 0]));
identifyParams.geometry = geom.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams, function (response) {
var parcelItems = [];
dojo.forEach(response, function (result) {
var feature = result.feature;
//add selected feature to graphics layer
feature.setSymbol(symbol);
map.graphics.add(feature);
if (result.layerName === 'SPL_NSDI') {
parcelItems.push(feature.attributes);
var parcelsStore = new dojo.data.ItemFileReadStore({ data: { identifier: 'ID', items: parcelItems } });
gridParcels.setStore(parcelsStore);
<table dojotype="dojox.grid.DataGrid" jsid="gridParcels" id="gridParcels" style="width:100%;height:100%;" selectionMode="none">
<thead >
<tr>
<th field="ID">ID</th>
<th field="STATION_NAME">STATION_NAME </th>
</tr>
</thead>
</table >
But how to bind the fetched items from ItemFileReadStore to table td not dojo data grid and table values should be vertical, Below is the code that how i fetched the items
var queryObj = {};
var value = null;
var staionName = null;
parcelsStore.fetch({
query: queryObj,
onItem: function (item) {
value = (parcelsStore.getValue(item, 'ID'));
staionName = (parcelsStore.getValue(item, 'STATION_NAME'));
// return value;
Result should be like this
ID 1
STATION_NAME Mysore
Please help on this issue..,.
Thanks!
