Hi Diana, thanks for the reply. I was able to implement some of that code into one of my existing drop down menus to improve it. But what I am trying to do with the legend is when you select the legend button, the left panel expands open with the legend contained inside it. And then I would like to have another button for my editing tools, where the tools would also appear in the left panel when the button is clicked. I don't think that will be very hard to do though once I figure out how to go about making the left panel expand when a button is selected. If there's any way you could assist me in getting started with this, I would really appreciate it.Thanks, Ryan
var titlePane = dijit.byId("paneEditor"); dojo.connect(titlePane, "toggle", function () { if (titlePane.open && _mapController.GetEnableEditing()) { if (_map.getScale() < _mapController.minEditScale) { if (!_mapController.isTemplatePickerInitialized) { initializeEditorTemplate(); titlePane.resize(); } if (!_mapController.isAttributeInspectorInitialized) { initializeAttributeInspector(); } } } });
<div id="baseLayersDropDown" class="baseLayersDiv" onClick="leftPanel1();" data-dojo-type="dijit/form/DropDownButton" data-dojo-props="iconClass:'',label:'Legend', showLabel: true, disabled: false"> <div data-dojo-type="dijit/TooltipDialog" class="tooltipDialogLayers"> <div id="divBaseLegendHolder" ></div> </div> </div>
function leftPanel1 () { domStyle.set(leftDiv.domNode, 'display', 'block'); }
require(["dojo/dom", "dojo/dom-class", "dojo/on", "dojo/dom-style"], function (dom, domClass, dojoOn, domStyle) { var sidebarCollapseDiv = dom.byId('sidebarCollapseButton'); var leftDiv = dijit.byId("leftDiv"); dojoOn(sidebarCollapseDiv, 'click', function (evt) { if (leftDiv.domNode.style.display === "none") { //domStyle.set(sidebarCollapseDiv, 'display', 'block'); domStyle.set(leftDiv.domNode, 'display', 'block'); domClass.remove(sidebarCollapseDiv, 'open'); domClass.add(sidebarCollapseDiv, 'close'); } else { //domStyle.set(sidebarCollapseDiv, 'display', 'none'); domStyle.set(leftDiv.domNode, 'display', 'none'); domClass.remove(sidebarCollapseDiv, 'close'); domClass.add(sidebarCollapseDiv, 'open'); } leftDiv.resize(); //domStyle.set(dom.byId('mapDiv'), 'width', '100%'); dijit.byId('mainDiv').resize(); _map.resize(true); _map.reposition(); //dijit.byId("mapDiv").refresh(); }); domStyle.set(sidebarCollapseDiv, 'display', 'block'); });
And would the other code you supplied (var titlePane = dijit.byId("paneEditor");...) go into that same function?
<div id="sidebarCollapseButton" class="sidebarCollapseButton.close" style="display:none;"></div> <div id="leftDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="display:block;"> <div id="paneLayers" class="titlePane" onClick="openSide();" data-dojo-type="dijit/TitlePane" data-dojo-props="title: 'Layers', open: true" > <div id="divLegendHolder"></div> </div> <div id="paneEditor" class="titlePane" data-dojo-type="dijit/TitlePane" data-dojo-props="title: 'Editor Tools', open: false" > <div id="editToolbarPane" class = "toolbarContentPane_TitlePane" dojotype="dijit/layout/ContentPane" region="top"> <div id="editToolbar" data-dojo-type="dijit/Toolbar"> <div id ="templateDiv"> </div> <div id ="editorDiv"> </div> </div> </div> <div id="editTemplateHolder" ></div> </div> </div>
function openSide () { domStyle.set(leftDiv.domNode, 'display', 'block'); domClass.remove(sidebarCollapseDiv, 'open'); domClass.add(sidebarCollapseDiv, 'close'); }
<script> var dojoConfig = { parseOnLoad: true, packages: [{ "name": "agsjs", //"location": location.pathname.replace(/\/[^/]+$/, "") + '/agsjs' "location": 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/2.04/xbuild/agsjs' // for xdomain load }] }; </script>
