<?php /*************************************************************************** * USAGE * [1] http://<this-proxy-url>?<arcgis-service-url> * [2] http://<this-proxy-url>?<arcgis-service-url> (with POST body) * [3] http://<this-proxy-url>?<arcgis-service-url>?token=ABCDEFGH * * note: [3] is used when fetching tiles from a secured service and the * JavaScript app sends the token instead of being set in this proxy * * REQUIREMENTS * - cURL extension for PHP must be installed and loaded. To load it, * add the following lines to your php.ini file: * extension_dir = "<your-php-install-location>/ext" * extension = php_curl.dll * * - Turn OFF magic quotes for incoming GET/POST data: add/modify the * following line to your php.ini file: * magic_quotes_gpc = Off * ***************************************************************************/ /*************************************************************************** * <true> to only proxy to the sites listed in '$serverUrls' * <false> to proxy to any site (are you sure you want to do this?) */ $mustMatch = true; /*************************************************************************** * ArcGIS Server services this proxy will forward requests to * * 'url' = location of the ArcGIS Server, either specific URL or stem * 'matchAll' = <true> to forward any request beginning with the URL * <false> to forward only the request that exactly matches the url * 'token' = token to include for secured service, if any, otherwise leave it * empty */ $serverUrls = array( array( 'url' => 'http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://sampleserver2.arcgisonline.com/ArcGIS/rest/services/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://sampleserver1a.arcgisonline.com/arcgisoutput/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://sampleserver1b.arcgisonline.com/arcgisoutput/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://sampleserver1c.arcgisonline.com/arcgisoutput/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://services.arcgisonline.com/ArcGIS/rest/services/', 'matchAll' => true, 'token' => '' ), array( 'url' => 'http://services1.arcgis.com/', 'matchAll' => true, 'token' => '' ) ); /***************************************************************************/ function is_url_allowed($allowedServers, $url) { $isOk = false; $url = trim($url, "\/"); for ($i = 0, $len = count($allowedServers); $i < $len; $i++) { $value = $allowedServers[$i]; $allowedUrl = trim($value['url'], "\/"); if ($value['matchAll']) { if (stripos($url, $allowedUrl) === 0) { $isOk = $i; // array index that matched break; } } else { if ((strcasecmp($url, $allowedUrl) == 0)) { $isOk = $i; // array index that matched break; } } } return $isOk; } // check if the curl extension is loaded if (!extension_loaded("curl")) { header('Status: 500', true, 500); echo 'cURL extension for PHP is not loaded! <br/> Add the following lines to your php.ini file: <br/> extension_dir = "<your-php-install-location>/ext" <br/> extension = php_curl.dll'; return; } $targetUrl = $_SERVER['QUERY_STRING']; if (!$targetUrl) { header('Status: 400', true, 400); // Bad Request echo 'Target URL is not specified! <br/> Usage: <br/> http://<this-proxy-url>?<target-url>'; return; } $parts = preg_split("/\?/", $targetUrl); $targetPath = $parts[0]; // check if the request URL matches any of the allowed URLs if ($mustMatch) { $pos = is_url_allowed($serverUrls, $targetPath); if ($pos === false) { header('Status: 403', true, 403); // Forbidden echo 'Target URL is not allowed! <br/> Consult the documentation for this proxy to add the target URL to its Whitelist.'; return; } } // add token (if any) to the url $token = $serverUrls[$pos]['token']; if ($token) { $targetUrl .= (stripos($targetUrl, "?") !== false ? '&' : '?').'token='.$token; } // open the curl session $session = curl_init(); // set the appropriate options for this request $options = array( CURLOPT_URL => $targetUrl, CURLOPT_HEADER => false, CURLOPT_HTTPHEADER => array( 'Content-Type: ' . $_SERVER['CONTENT_TYPE'], 'Referer: ' . $_SERVER['HTTP_REFERER'] ), CURLOPT_RETURNTRANSFER => true, CURLOPT_FOLLOWLOCATION => true ); // put the POST data in the request body $postData = file_get_contents("php://input"); if (strlen($postData) > 0) { $options[CURLOPT_POST] = true; $options[CURLOPT_POSTFIELDS] = $postData; } curl_setopt_array($session, $options); // make the call $response = curl_exec($session); $code = curl_getinfo($session, CURLINFO_HTTP_CODE); $type = curl_getinfo($session, CURLINFO_CONTENT_TYPE); curl_close($session); // set the proper Content-Type header("Status: ".$code, true, $code); header("Content-Type: ".$type); echo $response; ?>
