Nasif,here is the code of my config.xml<layer label="Urbanisme - Stedenbouw" type="dynamic" visible="true" alpha="0.8" name="PPAS" url="http://YourServer/ArcGIS/rest/services/Urbanisme/MapServer"> <sublayer id="0" popupconfig="popups/ppas.xml" /> <sublayer id="1" popupconfig="popups/lotissements.xml"/></layer>Direct i dont see anything wrong. Perharps using "sublayers"..Do you turn the visibility to "on" when you test?
Hi,I have customized the popup skin and all work fine.Now i would like to have as in the AttRelateInfoWinWidget widget the possibility to use a URL is form of text.For the popup have have see only the medialink possibility (Chart and image)Is it possible? Perhaps i miss something.David
an event layer get generated from x,y file..Data Type: XY Event Source
All Layers and Tables Layers: inspections.csv Events (0) Tables:
