<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"><html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7" /> <title>Create Map</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script> <script type="text/javascript"> dojo.require("esri.map"); function init() { var map = new esri.Map("map"); var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "JPEG"; //set the image type to JPEG, note default is PNG8. //Takes a URL to a non cached map service. var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://serverapp:8399/arcgis/services/HranicaSR2/MapServer", { "opacity": 0.5, "imageParameters": imageParameters }); map.addLayer(dynamicMapServiceLayer); } dojo.addOnLoad(init); </script> </head> <body class="tundra"> <div id="map" style="width:900px; height:600px; border:1px solid #000;"></div> Creates a map and adds an ArcGISDynamicMapServiceLayer.<br /> Map navigation using mouse: <ul> <li>Drag to pan</li> <li>SHIFT + Click to recenter</li> <li>SHIFT + Drag to zoom in</li> <li>SHIFT + CTRL + Drag to zoom out</li> <li>Mouse Scroll Forward to zoom in</li> <li>Mouse Scroll Backward to zoom out</li> <li>Use Arrow keys to pan</li> <li>+ key to zoom in a level</li> <li>- key to zoom out a level</li> <li>Double Click to Center and Zoom in</li> </ul> </body></html>
http://serverapp:8399/arcgis/rest/services/HranicaSR2/MapServer
tags instead of what you used. Anyway, one glaring problem that I see is that you're using the ArcGIS JS API version 1.6. This may be a deliberate choice of yours, but there is a much newer and better version out (v2.1). If you have mistakingly been using 1.6, then change <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
<script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.1"></script>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.1/js/dojo/dijit/themes/claro/claro.css">
