import os.path, math def main(): mystery_filename = r'C:\Project\_Forums\compareSignatures\in\infile.txt' folder = r'C:\Project\_Forums\compareSignatures\signatures' # folder = r'C:\Project\_Forums\compareSignatures\comp' infile = open(mystery_filename, 'r') text = infile.read() infile.close() mystery_signature = [mystery_filename] mystery_signature.append(average_word_length(text)) mystery_signature.append(type_token_ratio(text)) mystery_signature.append(hapax_legomana_ratio(text)) mystery_signature.append(average_sentence_length(text)) mystery_signature.append(avg_sentence_complexity(text)) weights = [0, 11, 33, 50, 0.4, 4] print "mystery_signature={0}".format(mystery_signature) # every file in this directory must be a linguistic signature files=os.listdir(folder) ## # create some signature files ## for this_file in files: ## compfilename = os.path.join(folder, this_file) ## compfile = open(compfilename, 'r') ## text = compfile.read() ## compfile.close() ## signature = [compfilename] ## signature.append(average_word_length(text)) ## signature.append(type_token_ratio(text)) ## signature.append(hapax_legomana_ratio(text)) ## signature.append(average_sentence_length(text)) ## signature.append(avg_sentence_complexity(text)) ## ## print "" ## for row in signature: ## print row this_file = files[0] signature = read_signature(os.path.join(folder,this_file)) best_score = compare_signatures(mystery_signature, signature, weights) best_author = signature[0] for this_file in files[1:]: signature = read_signature(os.path.join(folder,this_file)) score = compare_signatures(mystery_signature, signature, weights) if score < best_score: best_score = score best_author = signature[0] print( "best author match: {} with score {}".format(best_author, best_score)) def clean_up(s): ''' Return a version of string str in which all letters have been converted to lowercase and punctuation characters have been stripped from both ends. Inner punctuation is left untouched. ''' punctuation = '''!"',;:.-?)([]<>*#\n\t\r''' result = s.lower().strip(punctuation) return result def average_word_length(text): ''' Return the average length of all words in text. Do not include surrounding punctuation in words. text is a non-empty list of strings each ending in \n. At least one line in text contains a word.''' words = text.split() for word in words: average=sum(float(len(word)) for word in words)/float(len(words)) return average def type_token_ratio(text): ''' Return the type token ratio (TTR) for this text. TTR is the number of different words divided by the total number of words. text is a non-empty list of strings each ending in \n. At least one line in text contains a word. ''' uniquewords = {} words=0 for line in text.splitlines(): line=line.strip().split() for word in line: words+=1 if word in uniquewords: uniquewords[word]+=1 else: uniquewords[word]=1 TTR = float(len(uniquewords))/float(words) return TTR def hapax_legomana_ratio(text): ''' Return the hapax_legomana ratio for this text. This ratio is the number of words that occur exactly once divided by the total number of words. text is a list of strings each ending in \n. At least one line in text contains a word.''' uniquewords = dict() words = 0 for line in text.splitlines(): line = line.strip().split() for word in line: words += 1 word = word.replace(',', '').strip() if word in uniquewords: uniquewords[word] -= 1 else: uniquewords[word] = 1 unique_count = 0 for each in uniquewords: if uniquewords[each] == 1: unique_count += 1 HLR = float(unique_count)/float(words) return HLR def split_on_separators(original, separators): ''' Return a list of non-empty, non-blank strings from the original string determined by splitting the string on any of the separators. separators is a string of single-character separators.''' result = [] newstring='' for char in original: if char in separators: result.append(newstring) newstring='' if '' in result: result.remove('') else: newstring+=char return result def average_sentence_length(text): ''' Return the average number of words per sentence in text. text is guaranteed to have at least one sentence. Terminating punctuation defined as !?. A sentence is defined as a non-empty string of non-terminating punctuation surrounded by terminating punctuation or beginning or end of file. ''' words=0 Sentences=0 for line in text.split(): words+=1 sentence=split_on_separators(text,'?!.') for sep in sentence: Sentences+=1 ASL = float(words) / float(Sentences) return ASL def avg_sentence_complexity(text): '''Return the average number of phrases per sentence. Terminating punctuation defined as !?. A sentence is defined as a non-empty string of non-terminating punctuation surrounded by terminating punctuation or beginning or end of file. Phrases are substrings of a sentences separated by one or more of the following delimiters ,;: ''' Sentences=0 Phrases=0 sentence=split_on_separators(text,'?!.') for sep in sentence: Sentences+=1 Phrase=split_on_separators(text, ',;:') for n in Phrase: Phrases+=1 ASC = float(Phrases) / float(Sentences) return ASC def compare_signatures(sig1, sig2, weight): '''Return a non-negative real number indicating the similarity of two linguistic signatures. The smaller the number the more similar the signatures. Zero indicates identical signatures. sig1 and sig2 are 6 element lists with the following elements 0 : author name (a string) 1 : average word length (float) 2 : TTR (float) 3 : Hapax Legomana Ratio (float) 4 : average sentence length (float) 5 : average sentence complexity (float) weight is a list of multiplicative weights to apply to each linguistic feature. weight[0] is ignored. ''' result = 0 i=1 while i <=5: result +=(abs(sig1-sig2))*weight i+=1 return result def read_signature(filename): '''Read a linguistic signature from filename and return it as list of features. ''' cmpfile = open(filename, 'r') # the first feature is a string so it doesn't need casting to float result = [cmpfile.readline()] # all remaining features are real numbers for line in cmpfile: result.append(float(line.strip())) cmpfile.close() return result if __name__ == '__main__': main()
