protected void AttachMeasureAction(Map map) { if (!MeasureActionSelected && map != null) { MeasureActionSelected = true; //ToolLock = true; map.Layers.CollectionChanged += Layers_CollectionChanged; MeasureAction.Attach(map); MeasureAction.Execute(); } } protected void StartMeasureAction() { DisableMeasureAction(); foreach (Map map in InternalMaps) { map.PreviewMouseDown += Map_PreviewMouseDown; map.Cursor = Cursors.Hand; //Need to reset cursor because measure action changes it upon finish } } protected void DisableMeasureAction() { MeasureAction.Detach(); foreach (Map map in InternalMaps) map.PreviewMouseDown -= Map_PreviewMouseDown; MeasureActionSelected = false; //ToolLock = false; } //Events protected void Map_PreviewMouseDown(Object sender, System.Windows.Input.MouseButtonEventArgs e) { DisableMeasureAction(); AttachMeasureAction((Map)sender); } protected void Layers_CollectionChanged(Object sender, System.Collections.Specialized.NotifyCollectionChangedEventArgs e) { //Restart measure action when finished if(MeasureActionSelected) { if (e.OldItems != null) { for (Int32 i = 0; i < e.OldItems.Count; i++) { if (e.OldItems is GraphicsLayer && ((GraphicsLayer)e.OldItems).ID == null) { StartMeasureAction(); break; } } } } }
Try to execute your code asynchrounously from your event handler.Something like :Dispatcher.BeginInvoke(ActivateActionTool);
