Hello everybody, someone can tell me how I can do to make the Arcgis not change the characters when I export a table. I'm working with data in different languages, and when I saved they are all wrong. Thank you!
thank you for trying to help!
I don't use geodatabases, so I will toss that ball into the other court...with shapefiles the is a *.cpg file denoting the codepage... language settings are poorly documented in the help files and all search bring up stuff relating largely to server-ish, database-ish or arcpad settings. good luck
have you checked your codepage settings in ArcMap and outside? If they are fine inside, then the problem is external to ArcMap
