I am having the same problem when attempting to import a polygon. I do have cut out areas within the polygon leaving 3 donuts areas. Is that causing the issue?
I am trying to import a zipped polygon (just one) to do some analysis. However, anything I try is giving me errors and it will not import. My shapefile is not projected as it is an elementary school jurisdiction (not a district). There is only a .dbf, .shp, and .shx. Could that be the problem that it is not projected? Every time I zip the folder with the 3 files in it there's an additional folder that appears inside that I remove, or it gives me an error to check for any additional subfolders. That I have taken care of but I'm still not able to import. Here's the error: Can't read Shapefile due to server communication errors: Unable to extract shapefiles from zip. Please make sure there are no subfolders within the zipped file and try again. The file I'm trying to upload is attached.Thanks!
