If someone can give me some pointers on the steps to take and where I could upload it to I'll gladly make it available.
using System; using System.Net; using System.Windows; using System.Windows.Controls; using System.Windows.Documents; using ESRI.ArcGIS.Client.Geometry; using System.Collections.Generic; using System.Text.RegularExpressions; using System.Linq; using System.Collections.ObjectModel; using System.Text; namespace Geometry.Model { /// <summary> /// Converted from a php class by me to work in .NET c#. The class was taken from this link: http://trac.mapfish.org/trac/mapfish/browser/sandbox/aabt/MapFish/server/php/GeoJSON/WKT/WKT.class.php?rev=2399 /// </summary> public class WKTModel { static string _regExpTypeStr = @^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$; static string _regExpSpaces = @\s+; static string _regExpParenComma = @\)\s*,\s*\(; static string _regExpDoubleParenComma = @\)\s*\)\s*,\s*\(\s*\(; static string _regExpTrimParens = @^\s*\(?(.*?)\)?\s*$; public enum GeometryType { UNKNOWN, POINT, MULTIPOINT, LINESTRING, MULTILINESTRING, POLYGON, MULTIPOLYGON, GEOMETRYCOLLECTION } private WKTModel() { } /// <summary> /// Converts a geometry object to WKT. /// </summary> public static string ToWKT(Geometry g) { StringBuilder sb = new StringBuilder(); if (g is Envelope) { var p = g as Envelope; var pc = p.ToPolygon(); sb.AppendFormat("POLYGON ({0})", ConvertPointCollection(pc.Rings[0], true)); } else if (g is MapPoint) { var p = g as MapPoint; sb.AppendFormat("POINT ({0})", ConvertPoint(p).Replace(",", "")); } else if (g is MultiPoint) { var mp = g as MultiPoint; sb.AppendFormat("MULTIPOINT ({0})", ConvertPointCollection(mp.Points)); } else if (g is Polygon) { var p = g as Polygon; if (p.Rings.Count == 1) sb.AppendFormat("POLYGON ({0})", ConvertPointCollection(p.Rings[0], true)); else if (p.Rings.Count > 1) sb.AppendFormat("POLYGON ({0})", string.Join(",", p.Rings.Select(x => ConvertPointCollection(x, true)))); } else if (g is Polyline) { var l = g as Polyline; if (l.Paths.Count == 1) sb.AppendFormat("LINESTRING ({0})", ConvertPointCollection(l.Paths[0])); else if (l.Paths.Count > 1) sb.AppendFormat("MULTILINESTRING ({0})", string.Join(",", l.Paths.Select(x => ConvertPointCollection(x, true)))); } return sb.ToString(); } public static GeometryType GetGeometryType(string WKT) { if (string.IsNullOrEmpty(WKT)) return GeometryType.UNKNOWN; var matches = Regex.Matches(WKT, _regExpTypeStr); try { var mytype = matches.Count == 0 ? GeometryType.UNKNOWN : (GeometryType)Enum.Parse(typeof(GeometryType), matches[0].Groups[1].Value, true); return mytype; } catch (Exception ex) { return GeometryType.UNKNOWN; } } /// <summary> /// Parses the WKT and truns it into and ESRI Geometry object /// </summary> public static Geometry ToGeometry(string WKT, int WKID) { var geometry = new WKTModel().Read(WKT); geometry.SpatialReference = new SpatialReference(WKID); return geometry; } /// <summary> /// Parses the WKT and truns it into and ESRI geometry object /// </summary> private Geometry Read(string WKT) { if (!Regex.IsMatch(WKT, _regExpTypeStr)) return null; var matches = Regex.Matches(WKT, _regExpTypeStr); return Parse(ParseToGeometryType(matches[0].Groups[1].Value), matches[0].Groups[2].Value); } private GeometryType ParseToGeometryType(string type) { return (GeometryType)Enum.Parse(typeof(GeometryType), type, true); } /// <summary> /// Parses a section of the WKT into a geometry object /// </summary> private Geometry Parse(GeometryType type, string str) { var points = new PointCollection(); switch (type) { case GeometryType.POINT: var coords = RegExplode(_regExpSpaces, str); double x; double y; var isXValid = double.TryParse(coords[0], out x); var isYValid = double.TryParse(coords[1], out y); if (isXValid && isYValid) return new MapPoint(x, y); else return null; case GeometryType.MULTIPOINT: foreach (var p in str.Trim().Split(',')) points.Add(Parse(GeometryType.POINT, p) as MapPoint); return new MultiPoint(points); case GeometryType.LINESTRING: foreach (var p in str.Trim().Split(',')) points.Add(Parse(GeometryType.POINT, p) as MapPoint); var line = new ESRI.ArcGIS.Client.Geometry.Polyline(); line.Paths.Add(points); return line; case GeometryType.MULTILINESTRING: var lines = RegExplode(_regExpParenComma, str); var nestedPoints = new List<PointCollection>(); foreach (var l in lines) { var myline = Regex.Replace(l, _regExpTrimParens, "$1"); nestedPoints.Add(((Polyline)Parse(GeometryType.LINESTRING, myline)).Paths[0]); } return new Polyline() { Paths = new ObservableCollection<PointCollection>(nestedPoints) }; case GeometryType.POLYGON: var rings = RegExplode(_regExpParenComma, str); var ringPoints = new List<PointCollection>(); foreach (var r in rings) { var ring = Regex.Replace(r, _regExpTrimParens, "$1"); var pline = Parse(GeometryType.LINESTRING, ring) as Polyline; ringPoints.Add(pline.Paths[0]); } return new Polygon() { Rings = new ObservableCollection<PointCollection>(ringPoints) }; case GeometryType.MULTIPOLYGON: var polygons = RegExplode(_regExpDoubleParenComma, str); var multiPolyRings = new List<PointCollection>(); foreach (var p in polygons) { var polygon = Regex.Replace(p, _regExpTrimParens, "$1"); var poly = Parse(GeometryType.POLYGON, polygon) as Polygon; multiPolyRings.AddRange(poly.Rings); } return new Polygon() { Rings = new ObservableCollection<PointCollection>(multiPolyRings) }; case GeometryType.GEOMETRYCOLLECTION: throw new NotImplementedException(); // str = preg_replace('/,\s*([A-Za-z])/', '|$1', str); // $wktArray = explode('|', trim(str)); // foreach ($wktArray as $wkt) // { // components[] = $this->read($wkt); // } // return new GeometryCollection(components); default: return null; } } /// <summary> /// Split string according to first match of passed regEx index of regExes /// </summary> /// <param name="regEx"></param> /// <param name="str"></param> /// <returns></returns> protected List<string> RegExplode(string regEx, string str) { var matches = Regex.Matches(str, regEx); return matches.Count == 0 ? new List<string> { str.Trim() } : str.Trim().Split(new string[] { matches[0].Value }, StringSplitOptions.None).ToList(); } private static string ConvertPointCollection(PointCollection pc, bool wrapInParens = false) { StringBuilder sb = new StringBuilder(); if (pc != null) { foreach (var p in pc) sb.AppendFormat(ConvertPoint(p)); } //trim the trailing comma if (sb.Length > 0) { sb = sb.Remove(sb.Length - 1, 1); if (wrapInParens) sb = sb.Insert(0, "(").Append(")"); } return sb.ToString(); } private static string ConvertPoint(MapPoint p) { return string.Format("{0} {1},", p.X, p.Y); } } }
Geometry geom = WKTModel.ToGeometry("POLYGON(...", 4269); string wkt = WKTModel.ToWKT(geom);
/// <summary> /// Converts a geometry object to WKT. /// </summary> public static string ToWKT(Geometry g) { StringBuilder sb = new StringBuilder(); if (g is Envelope) { var p = g as Envelope; var pc = p.ToPolygon(); sb.AppendFormat("POLYGON ({0})", ConvertPointCollection(pc.Rings[0], true)); } ...more code below
Hello Justin
I came across your blog post here and I am reaching out to you to ask that how can I use this code. Preferably, if you could confirm that the above sample code can be used under the terms of an official OSI license, such as the Apache License v.2, it would be much appreciated.
Regards,
Weranga
You are welcome to use the code however you want. I wrote that quite a long time ago referencing several different sources online but I couldn't tell you what those sources are now. If you do publish this code I would like a nod in the article.
There is not a ToPolygon() method. You need to make an extension method if you want and it would be something simple. Using the two points to construct a polygon. Below is not tested or probably not even the correct syntax, but it should give you the jest of what needs to happen. Just remember to always close your polygon (last and first point are the same). Also remember to construct your polygon in a counterclockwise method to make the area within the points inclusive. Otherwise clockwise means that is exclusive area, basically a hole.
Hope this helps.
var e = extent; var poly = new List<Point>(); poly.Add(new Point(e.MinX, e.MinY, e.SpatialReference)); poly.Add(new Point(e.MaxX, e.MinY, e.SpatialReference)); poly.Add(new Point(e.MaxX, e.MaxY, e.SpatialReference)); poly.Add(new Point(E.MinX, e.MaxY, e.SpatialReference)); poly.Add(new Point(e.MinX, e.MinY, e.SpatialReference));//close the polygon
