Our ESRI Incident #996584 was put on hold on January 12, 2012 and we never heard anything again. The only recommendation given was to install our SQL SErver database on the same machine as SDE. I don't think the repesentative we were dealing with knew what he was doing.
I realise this post was created a long time ago, however this is a problem we have only recently started seeing. We have connections to several SDE instances and this issue occurs with only one. Did anyone ever get a resolution as to what can couse this issue?
Regards
Ian McCrorie
that's strange we are having the same issues as well since 1/3/12..Any solutions yet.
We are having a similar issue with 10 Client, 9.3.1 SDE and SQL 2008, any solutions or workarounds?
We are intermittently getting the error "Failed to connect to database. Network I/O Error" when opening an ArcSDE connection (9.3.1 client, 9.3.1 SDE, Oracle 11g) when using a 3-tier connection. When attempting to open a second time the connection works. We have turned on SDEVERBOSE and in the log from that we see: SDE_Oracle Error: 942 ORA-00942: table or view does not exist. Because it is intermittent ESRI support has not yet been able to identify the source of this problem. If anyone has a thought of what we should check for please let me know, thanks!Bob
