Public Function ConvertToADONETDataTableFromLayer(ByVal inLayer As IFeatureLayer) As DataTable Try Dim tmpDT As New DataTable("tmpDT") Dim column As DataColumn Dim pTable As ITable = inLayer.FeatureClass Dim pFields As IFields = pTable.Fields Dim pCur As ICursor = pTable.Search(Nothing, False) For c = 0 To pCur.Fields.FieldCount - 1 column = New DataColumn() column.ColumnName = (pFields.Field(c).Name) If pFields.Field(c).Type = esriFieldType.esriFieldTypeString Then column.DataType = System.Type.GetType("System.String") ElseIf pFields.Field(c).Type = esriFieldType.esriFieldTypeInteger Then column.DataType = System.Type.GetType("System.Int32") ElseIf pFields.Field(c).Type = esriFieldType.esriFieldTypeDouble Then column.DataType = System.Type.GetType("System.Double") ElseIf pFields.Field(c).Type = esriFieldType.esriFieldTypeDate Then column.DataType = System.Type.GetType("System.DateTime") ElseIf pFields.Field(c).Type = esriFieldType.esriFieldTypeSingle Then column.DataType = System.Type.GetType("System.Single") ElseIf pFields.Field(c).Type = esriFieldType.esriFieldTypeBlob Then column.DataType = System.Type.GetType("System.Byte") End If column.ReadOnly = False tmpDT.Columns.Add(column) Next Dim pRow As IRow = pCur.NextRow Dim newRow As DataRow Do Until pRow Is Nothing newRow = tmpDT.NewRow() newRow.BeginEdit() For cols = 0 To pCur.Fields.FieldCount - 1 newRow(cols) = pRow.Value(pRow.Fields.FindField(pFields.Field(cols).Name)) Next newRow.EndEdit() tmpDT.Rows.Add(newRow) tmpDT.AcceptChanges() pRow = pCur.NextRow Loop Return tmpDT Catch ex As Exception MsgBox(ex.ToString) Return Nothing End Try End Function
Thanks jojolover for your reply,I'm dealing with road segments(segment layer) and crash data(point layer) for different year. So when I run the program with crash data for say 2008 it would generate an attribute table for the road segment for 2008, similarly when crash data for 2009 is selected the attribute table for road segment is modified. I need to capture these different attribute tables and save them under different names.I'm very new to ArcGIS and don't know much. Can you please explain to me how save the whole attribute to a collection type? Thanks once again
