var newGraphic:Graphic = ObjectUtil.clone(exisitngGraphic)
package ee.alphagis.utils { import com.esri.ags.Graphic; import com.esri.ags.geometry.Geometry; import com.esri.ags.symbols.Symbol; import mx.core.IFactory; public class MyGraphicUtils { public static function cloneGraphic(graphic:Graphic):Graphic { if (!graphic) { return null; } var geometry:Geometry = graphic.geometry; var symbol:Symbol = graphic.symbol; var attributes:Object = graphic.attributes; var autoMoveToTop:Boolean = graphic.autoMoveToTop; var checkForMouseListeners:Boolean = graphic.checkForMouseListeners; var infoWindowRenderer:IFactory = graphic.infoWindowRenderer; var result:Graphic = new Graphic(geometry, symbol, attributes); result.autoMoveToTop = autoMoveToTop; result.checkForMouseListeners = checkForMouseListeners; result.infoWindowRenderer = infoWindowRenderer; return result; } } }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx"> <!-- Adobe FLEX SDK ver. 4.5.1 --> <!-- ArcGIS API for FLEX ver. 2.5 --> <s:layout> <s:VerticalLayout paddingBottom="20" paddingLeft="20" paddingRight="20" paddingTop="20" /> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.Graphic; import com.esri.ags.SpatialReference; import com.esri.ags.geometry.MapPoint; import com.esri.ags.symbols.SimpleMarkerSymbol; import ee.alphagis.utils.MyGraphicUtils; import mx.controls.Alert; import mx.utils.StringUtil; private var _pattern:String = "base={0}, geometry={1}, name={2}, stamp={3}\n\nclone={4}, geometry={5}, name={6}, stamp={7}"; protected function button1_clickHandler(event:MouseEvent):void { var attr:Object = new Object(); attr.name = "qwerty"; attr.date = new Date(); var geometry:MapPoint = new MapPoint(654, 456, new SpatialReference(4326)); var symbol:SimpleMarkerSymbol = new SimpleMarkerSymbol("circle", 16, 0x00ff56); var baseGraphic:Graphic = new Graphic(geometry, symbol, attr); var clonedGraphic:Graphic = MyGraphicUtils.cloneGraphic(baseGraphic); var message:String = StringUtil.substitute(_pattern, baseGraphic.toString(), baseGraphic.geometry.type, baseGraphic.attributes["name"], baseGraphic.attributes["date"], clonedGraphic.toString(), clonedGraphic.geometry.type, clonedGraphic.attributes["name"], clonedGraphic.attributes["date"]); Alert.show(message); } ]]> </fx:Script> <s:Button label="clone" click="button1_clickHandler(event)"/> </s:Application>
cspring,http://forums.arcgis.com/threads/31993-Can-t-add-the-same-Graphic-twice-to-a-GraphicsLayer?p=107453#post107453Question to you: Can you tell, what is the base idea? Why do you need in 2 absolutely equals graphics?
var newGraphic:Graphic = deepClone(existingGraphic); newGraphic.attributes = existingGraphic.attributes; newGraphic.geometry = existingGraphic.geometry;
