I'm trying to run a point density analysis and keep getting the following errors. Attached below. I'm using model builder to run the point density analysis.
before you try anything else, move the source file to a file without spaces and other stuff... same for the destination
A F is a usb of other type of non-real drive... move it to a desktop folder
Is there enough disk space on the destination drive?
-Adam Z
Thank you, I moved it into it's own file database. Everytime I do run I get something different from tutorials I've been looking at. This is how my density map looks like. What's wrong when I run the model? Is my data bad?
Density map.
My data.
go to the layer's properties, select symbology and choose a different colour ramp... try for a lighter one than B to W
Point Density—Help | ArcGIS Desktop
It's still not overlaying.
I want it to look like this. I got this from a video, I'm going through the steps as he is but somehow my maps come up in one big block and it's not overlayed and looks like the one above
well you haven't indicated the options you used... which are probably the defaults... which you should think about. And I just want to check that you want point density and not kernel density Kernel Density—Help | ArcGIS Desktop they are slightly different in their expression although it is magnitude per unit area as a base
