I tried to run a watershed delimitation on a small piece of 10m DEM in Central Washington State. I was getting some strange results and when I examined the accumulation grid, I found that a seam in the DEM was causing all the flow from an adjacent drainage to get captured by my drainage. I set about trying to correct this DEM. I figured I'd just go Raster to Multipoint, create a point FC with Z values to act like little dams and channels in the surface, create a new terrain from the multipoints and the new point feature class, then terrain to raster, and rerun the watershed. But editing the point feature class has become my problem. When I created the points layer, I created it to contain Z-values, and I added an attribute called VALUES, and when editing, I stuck the desired corrected elevation into the VALUES attribute. The only way I could figure out to get the corrected elevation into the Z-values while editing was by editing the vertices under Sketch Properties, and I could only do one at a time. I thought I would just "Populate Zs from attributes". But after I got this far, it seems that "Populate Zs from attributes" is only available from Production Z Management and Production Editing, but I think Production Editing is only available in the Nautical or Aeronautical extensions which I don't have. Searching support I found VBA solutions to updating Z values from attributes, but that seems to be only applicable to 9.x. I'm trying to figure out how to do this in 10.0, SP3.
def shiftXCoordinate(shape): shiftValue = 100 point = shape.getPart(0) point.X += shiftValue return point
def assignZCoordinate(shape, z_Value): point = shape.getPart(0) point.Z = z_Value return point
