NIM073706: Running the Add Attachments geoprocessing tool returns the green warning message, "Cannot add file 'C:\student\seattletrips.jpg' to feature with OID = 1" when adding attachments to a target dataset that is registered as versioned.Version found: 10.1The documented workarounds for the bug are - Workaround1: Run the tool on a file geodatabase then copy/paste back into sde.Workaround2: Make a copy of the feature class in sde and run the tool on the copy without registering it as versioned.Please keep in mind there are negative implications to unregistering a feature class as versioned. To minimize these, I would recommend taking a full, verified backup and compressing to a state 0 before unregistering the feature class as versioned and adding attachments.Below is a link to the resource center documentation which discusses unregistering the data as versioned. It mentions steps needed to carry out to prevent data loss when you unregister data as versioned.
