FeatureLayer.fullExtent.spatialReference, orFeatureLayer.graphics -> graphic.geometry.spatialReference
var map; var gPoint; var gsvc; var gGraphic; var graphic; var locator; var currentLocation; var watchLocation; var myQueryTask; var myQuery; var graphic1; var infoSBITemplate; require(["dojo/ready", "dojo/on", "esri/map", "esri/config", "esri/dijit/Geocoder", "esri/geometry/screenUtils", "esri/geometry/Extent", "esri/geometry/Point", "esri/geometry/webMercatorUtils", "esri/tasks/locator", "esri/graphic", "esri/SpatialReference", "esri/layers/FeatureLayer", "esri/layers/KMLLayer", "esri/tasks/QueryTask", "esri/tasks/query", "esri/tasks/RelationParameters", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/PictureMarkerSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/InfoTemplate", "esri/dijit/BasemapGallery", "esri/arcgis/utils", "dojo/_base/array", "dojo/_base/Color", "dojo/number", "dojo/parser", "dojo/dom", "dojo/dom-construct", "dojo/query", "dijit/registry", "dijit/form/Button", "dijit/form/TextBox", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dijit/layout/TabContainer", "dijit/Menu", "dijit/TitlePane", "dojo/domReady!" ], function (ready, on, Map, esriConfig, Geocoder, screenUtils, Extent, Point, webMercatorUtils, Locator, Graphic, SpatialReference, FeatureLayer, KMLLayer, QueryTask, Query, RelationshipParameters, GeometryService, BufferParameters, SimpleMarkerSymbol, SimpleLineSymbol, PictureMarkerSymbol, Font, TextSymbol, InfoTemplate, BasemapGallery, arcgisUtils, arrayUtils, Color, number, parser, dom, domConstruct, query, registry) { ready(function () { parser.parse(); // esri.config.defaults.io.proxyUrl = "http://localhost:53303/proxy/proxy.ashx"; // for ASP.net application use this proxy. // esri.config.defaults.io.proxyUrl = "/proxy"; esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx"; esri.config.defaults.io.alwaysUseProxy = false; // var startExtent = new Extent(2264982.7047277316, 6425602.130388378, 1726864.6604362514, 8240522.929991121, // new SpatialReference({ wkid: 102100 })); // var initialExtent = new Extent({ "xmin": -2550392, "ymin": 6093330, "xmax": 1852380, "ymax": 9028512, "spatialReference": { "wkid": 102100 } }); var initialExtent = new Extent({ "xmin": -2335145.742961492, "ymin": 6433321.958737379, "xmax": 1656701.6222024914, "ymax": 8248242.758340122, "spatialReference": { "wkid": 102100 } }); map = new Map("map", { extent: initialExtent, basemap: "streets", zoom: 3, sliderPosition: "top-right", sliderStyle: "small" }); // Geocoder Widget var geocoder = new Geocoder({ arcgisGeocoder: { Placeholder: "Find a place" }, autoComplete: true, map: map }, dom.byId("Search")); geocoder.startup(); // map.on("load", enableSpotlight); geocoder.on("select", showFindLocation); geocoder.on("clear", removeSpotlight); function showFindLocation(evt) { map.graphics.clear(); gPoint = evt.result.feature.geometry; var gSymbol = new SimpleMarkerSymbol(); gSymbol.setStyle(SimpleMarkerSymbol.STYLE_SQUARE).setColor(new Color([255, 0, 0, 0.5])); gGraphic = new Graphic(gPoint, gSymbol); map.graphics.add(gGraphic); map.infoWindow.setTitle("Search Result"); map.infoWindow.setContent(evt.result.name); map.infoWindow.show(evt.result.feature.geometry); var spotlight = map.on("extent-change", function (extentChange) { var geom = screenUtils.toScreenGeometry(map.extent, map.width, map.height, extentChange.extent); var width = geom.xmax - geom.xmin; var height = geom.ymin - geom.ymax; var max = height; if (width > height) { max = width; } var margin = '-' + Math.floor(max / 2) + 'px 0 0 -' + Math.floor(max / 2) + 'px'; query(".spotlight").addClass("spotlight-active").style({ width: max + "px", height: max + "px", margin: margin }); spotlight.remove(); }); } function enableSpotlight() { var html = "<div id='spotlight' class='spotlight'></div>" domConstruct.place(html, dom.byId("map_container"), "first"); } function removeSpotlight() { query(".spotlight").removeClass("spotlight-active"); map.infoWindow.hide(); map.graphics.clear(); } // Buffer -Point features based geocoder widget location gsvc = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); on(dojo.byId("Buffer"), "click", buffer); function buffer() { map.graphics.clear(); var bufferParameters = new BufferParameters(); bufferParameters.distances = [dojo.byId("distance").value]; // bufferParameters.distances = [1]; bufferParameters.bufferSpatialReference = new SpatialReference({ wkid: 102100 }); bufferParameters.outSpatialReference = map.spatialReference; bufferParameters.unit = GeometryService[dojo.byId("unit").value]; bufferParameters.geometries = [gPoint]; gsvc.buffer(bufferParameters, bufferDraw); } function bufferDraw(geometries) { var symbol = new esri.symbol.SimpleFillSymbol("none", new esri.symbol.SimpleLineSymbol("solid", new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])); graphic1 = new esri.Graphic(geometries[0], symbol); map.graphics.add(graphic1); addSBILocations(graphic1); } var rsymbol = new esri.symbol.PictureMarkerSymbol({ "angle": 0, "xoffset": 0, "yoffset": 10, "type": "esriPMS", "url": "http://static.arcgis.com/images/Symbols/Shapes/YellowPin1LargeB.png", "contentType": "image/png", "width": 24, "height": 24 }); function addSBILocations(Results) { // SBI Branch Locations - Feature Service created by Ganesh infoSBITemplate = new InfoTemplate("SBI Bank Locations", "Bank Name: ${BankName}<br/>" + "Bank Address: ${BankAddres}<br/>" + "Manager Name: ${Manager}<br/>" + "Opening Time: ${Time}"); var flSBIUrl = "http://services1.arcgis.com/rHig23wEINZ1MKYI/arcgis/rest/services/SBI_BankLocation/FeatureServer/0"; var flSBI = new FeatureLayer(flSBIUrl, { // mode: FeatureLayer.MODE_SELECTION, mode: FeatureLayer.MODE_SNAPSHOT, outFields: ["BankName", "BankAddres", "Manager", "Time"], infoTemplate: infoSBITemplate }); var rsymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE).setColor(new Color([255, 0, 0, 0.5])); flSBI.setSelectionSymbol(rsymbol); // map.addLayer(flSBI); var mySBIQueryTask = new QueryTask(flSBIUrl); var mySBIQuery = new Query(); mySBIQuery.returnGeometry = true; mySBIQuery.outFields = ["BankName", "BankAddres", "Manager", "Time"]; mySBIQuery.geometry = Results.geometry; mySBIQuery.spatialRelationship = Query.SPATIAL_REL_INTERSECTS; mySBIQueryTask.execute(mySBIQuery, addPoints); } function addPoints(fset) { map.graphics.clear(); alert("Finally Reached!!!"); var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25])); var resultFeatures = fset.features; for (var i = 0, il = resultFeatures.length; i < il; i++) { var pt_graphic = resultFeatures; pt_graphic.setSymbol(rsymbol); pt_graphic.setInfoTemplate(infoSBITemplate); map.graphics.add(pt_graphic); } // var resultExtent = graphicsUtils.graphicsExtent(resultFeatures); var resultExtent = esri.graphicsExtent(resultFeatures); map.setExtent(resultExtent); } }); });
flSBI.selectFeatures(mySBIQuery, FeatureLayer.SELECTION_NEW);
flSBI.selectFeatures(mySBIQuery, FeatureLayer.SELECTION_NEW, function(features) { if (features) { alert("Number of features selected: " + features.length); } });
map = new Map("map", { extent: initialExtent, basemap: "osm", zoom: 3, sliderPosition: "top-right", sliderStyle: "small" });
var mySBIQueryTask = new QueryTask(flSBIUrl); var mySBIQuery = new Query(); mySBIQuery.returnGeometry = true; mySBIQuery.outFields = ["BankName"]; mySBIQuery.outSpatialReference = { wkid: 102100 };
bufferParameters.distances = [parseInt(dojo.byId("distance").value)];
mySBIQuery.outSpatialReference = new SpatialReference({ wkid: 102100 });
