Hi Carlos,
I don't think we have the exact same code available as a python script. However if your ultimate goal is to create a network dataset from TomTom Multi-Net data, you might want to check out the street data processing tools.
Hope this helps
Deelesh
Turn Table to Turn Feature Class tool is meant to convert ArcView 3.x or ArcInfo Workstation Turn table. So the tool expects the input to be in that format.To convert turn data from vendors such as TeleAtlas, try this VBA sample. You will have to change the names in the "Settings" section in the code.I was able to successfully run this sample on my test data with ArcGIS 10 and It also works in 9.3/9.3.1As VBA will not be supported with ArcGIS after 10.0 release, we will make this sample available as a python script tool in near future.
Turn Table to Turn Feature Class tool is meant to convert ArcView 3.x or ArcInfo Workstation Turn table. So the tool expects the input to be in that format. To convert turn data from vendors such as TeleAtlas, try this VBA sample. You will have to change the names in the "Settings" section in the code.I was able to successfully run this sample on my test data with ArcGIS 10 and It also works in 9.3/9.3.1As VBA will not be supported with ArcGIS after 10.0 release, we will make this sample available as a python script tool in near future.
Hello Deelesh,I really appreciate the details you provided now i am able to open VBA editor and i have copied that in the editor.But i have confustion regarding the TurnTable.I have following data :1. Street feature class from Tele Atlas Multinet2.Maneuvers Point Feature class from Tele Atlas Multinet3.Maneuvers Path Table from Tele Atlas MultinetIs there any data mining or pre processing i have to do on the Maneuvers data to create the turn table and then use that turn table to get Turn Feature class in ESRI style.sTurnFCName = "MyNewTurnFC" //the turn feature class in ESRI stylesStreetsFCName = "MyStreets" //Tele Atlas NW street datasTurnTableName = "MyTurnTable" //no ideaPlease suggestThanksManish Gohil
